Shaving antenna
Old Jan 12, 2005 | 07:00 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
Shaving antenna
So my power antenna doesnt work any more, no problem, i listen to cd's, and i still get good radio pickup. This might sound cheap but its all I need right now
Can I just take out the antenna, and somehow get some margalss/bondo to sit in there and then just paint over it for now? Or am I gonna hit a bump and watch this thing fly out? just wondering cause If this method works Im gonna do it as a temporary fix until i get $$ for a paint job
Old Jan 12, 2005 | 07:05 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
i got a quote from a body shop to shave mine and paint my car for 400. sounds like a deal to me.
Kyle
Old Jan 12, 2005 | 07:06 PM
Car: 1987 Z28
macco? all i want to do is shave mine for now, without having to paint the whole car yet, cause i have some exact match paint left i used when i got my new hood
Old Jan 12, 2005 | 07:20 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Weld the hole shut. Bondo might last for a little while, but it will eventually crack. I welded my antenna hole shut- I think it looks 100% better than having one.
Old Jan 12, 2005 | 08:04 PM
Car: 1987 Z28
***problem*** i dont have a welder
So if I sand down to the metal around the area and build up the bondo....it should work? heres my awsome paint chop, as you can see i went on a shaving spree
i also lowered it, thats why the rockers look out of whack
Old Jan 12, 2005 | 11:16 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
You should be able to find someone with a welder and throw em some beer money to do it, if you lived in colorado i'd say bring it by. Shaving anything is best done with metal and finished with filler door handles, antennas, lockholes all shoudl be welded first.
I cut a piece of metal off my sister old fender we still had laying around when she smashed up her truck, trimmed it to fit the hole, held it form underneath and tacked all the way around and then in the center till it was sealed and close to the stock height, then used an extremely light glaze of filler to finish it. Get complements on it all the time people say it was a good finish job since unless you know camaros had a antenna there you dont think it ever had one.
I bought a new antenna assembly from autozone and mounted it under my dash, theres pics somewhere of where i ran it so you can look up my name and like shaved antenna and you'll see antenna was 10.99 and welding was free since i'm a welder Get great radio fm or even am reception and you never see it.
I'd suggest definately getting rid of the door strip down the centers look much better but i dont care to much for 3rd gens with shaved handles and locks, door looks to bland to me, you should mold in a set of grand am or something like that handles that mount flush, that be cool...wish i had done it
Old Jan 13, 2005 | 10:15 AM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
and Im sayin cuz I forgot to shave my antenna....too late now
Old Jan 14, 2005 | 01:17 AM
Car: 91 Camaro RS
Engine: TBI
Yea buy you got candy paint so who cares
And i'm going for not painting mine candy
Old Jan 14, 2005 | 07:23 AM
all this 'doh-in' we're doin is starting to hurt my head....gotta think these things through
Old Jan 14, 2005 | 09:02 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I shaved mine just by gluing a piece of metal in there to hold the bondo, then leveled it with the filler. Looks great but I can't tell you how long it'll last becuase its only be 6 months.
Old Jan 14, 2005 | 07:28 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i shaved my antenna.
tip: i put my antenna under the dash, in the plastic track the power mirror harness goes threw across the firewall to the passenger side.
works
Old Jan 14, 2005 | 10:36 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Does anyone know where you can get the ones that are a thin little sticker that has the wire in it? Similar to the antennas that were made right into the glass. I was thinking you could just run one of those thin wire antennas along the top of the windshield and into the pillar and it would never be seen.
Old Jan 14, 2005 | 10:47 PM
Car: 1987 Z28
Thanx guys Its been way to cold to do it yet, so I will post pics when it warms up
And TZFbird i heard radio shack has them
Old Jan 15, 2005 | 01:39 AM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
Shaved mine.. I just put the antenna under the dash pad.. didn't cut any wires or anything. I just kind of weaved the antenna under those small vents under the dash pad... very easy to do, you'd never know it was there.
Old Jan 15, 2005 | 06:59 AM
heres a good question since i didnt shave my antenna. Since its an electric one, where to I 'pull the plug on it' to keep it down? Do I need to take out the passenger fender well to get to it?
Old Jan 15, 2005 | 02:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
hey 83, weren't you going to sell that beast??
I'm going to be shaving my antennae sooner or later, planned on just using fiberglass mat... Suppose I could use a stick welder to tack in a piece of sheet metal, then fiberglass bondo to smooth it out? I'm buying a stick welder today....
oh yea, I don't think radio shack makes anything for cars anymore...
but how could you put your factory antennae under your dash pad... would that still work? I figured it'd be really big and bulky...
Personally i'm going to keep an eye out for the aftermarket wire-in-sticker style one, my brother has a crown vic with a factory antennae in the rear glass, works well.... -J
Old Jan 15, 2005 | 06:36 PM
Car: 1987 Z28
Couldnt bring myself to do it lol so im keeping it
Old Jan 15, 2005 | 07:07 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Psh bring it by my school shop and we can both shave 'em together. Now I wanna do mine too. The shop has all the needed supplies.
Old Jan 15, 2005 | 08:02 PM
Car: 1987 Z28
yeah we got an autobody and mechanics shop, but i really dont trust my car there, even if im with it at all times. I could always goto car club (sounds lame i know) lol and i could do it there. But yea, I think im just gonna do it in the comfort of home even though its cold as hell
Old Jan 15, 2005 | 08:14 PM
305q_ta86's Avatar
Transmission: 5 spd
car club? huh?
Old Jan 15, 2005 | 08:31 PM
Car: 1987 Z28
every tuesday we can go into autobody and do whatever we want to our cars.....but yeah, thats where i painted my hood
Old Jan 15, 2005 | 08:49 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
someone i know is shaving their antenna hole in an 86 chevy pickup fender right now, he is using fiberglass mat and then green body putty coat
i wont shave mine on my 82 t/a, going to leave it stock factory 82 appearance
good luck
Old Jan 15, 2005 | 09:16 PM
jay92,85,79's Avatar
Car: 85z28,
I would weld it its the only way u know for sure its not going to fall out. If no welder I would go get some metal gule(auto body suppily shop) and grind to bare metal. And glue it. Idid mine on my bird . welded it. Cam out nice
Old Jan 15, 2005 | 09:17 PM
Car: 85z28,
ground down
Old Jan 15, 2005 | 09:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
looks good jay, can't wait until you do mine too.
Frozer!!!
Jan 19, 2024 04:55 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
scottmoyer
Sep 7, 2015 07:06 PM
madsv1000
Aug 20, 2015 06:45 AM
