Anyone have CB radios?
Old Jan 15, 2005 | 11:08 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I would like to see some interior installs.I just bought one off of ebay but it dosent come with a antenna.Can I use my normal FM radio antenna or is there a multi one available? like one size sits all?
thanks
Old Jan 16, 2005 | 12:53 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
There is a line that u can get from Radio Shack that will let you use your fender mounted antenna or window antenna as a CB antenna. But your transmission and receive distance will be very short.
I used one when I travelled cross country, but used a 6 foot antenna with a magnetic base just behind the Ttop area. Got about a 9 to 10 mile range. Just enough time to hear where the truckers see the highway patrol cars.
But a "smokey" report has a residual effect. Truckers will be reporting a Highway Patrol car in the same location for hours as they pass it down the line to each other. When the HP has been gone from that location for awhile.
Jim.
Old Apr 17, 2005 | 10:14 PM
FireChicken2.8's Avatar
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
does anyone have pics of their antennas? i just can't imagine a 6 foot antenna on a 3rd gen. but i want better reception from my cb.
Old Apr 17, 2005 | 11:49 PM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
If your going to get an antenna for your f-body, you might as well wear a cowboy hat, have sally field riding shotgun, and call yourself "the Bandit".
Old Apr 18, 2005 | 03:02 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I've got one of the handheld units mounted below the seat with the antenna ran through the stock fender mounted one. You can't even tell I have it. Actually, most times I forget. But it helps when cruising around with my 4x4 buddies.
Old Apr 18, 2005 | 06:52 AM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
lol this guy who came and picked up a motor had one on. I was like whats that for your gps. He said no the truckers tell me where the cops are so i can go fast . i was like damn. lol STI
Old Apr 18, 2005 | 03:27 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Here's mine: Uniden 510XL I cut out the ashtray, and slid it in there. I hung the mic from the dash, by my knee. Antenna is a thru-the-glass type from Radio Shack. Works pretty well for as short as it is.
Old Apr 18, 2005 | 03:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i use mine ONLY on road trips....
its just a handheld one.... one wire plugs into the cig outlet.
i got a rubberducky antenna from radioshack... sticks to the windshield right by the Apillar..
i still get about 7-10mile range.... and i dont look like bandit.. and i didnt screw anything into my car.
Old Apr 18, 2005 | 04:16 PM
Car: 2002 SS
Engine: Ls1
whats so great about the cb radios, how does the cb world work.
Old Apr 18, 2005 | 04:31 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
I have a cb in my car tuned in to police channels so I can tell if they coming after us when we are having some not so legal street races.
Old Apr 18, 2005 | 08:31 PM
yeah, i am thinking i will just continue using my hidden one.
Old Apr 18, 2005 | 08:41 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
Yes i do, on my truck
Old Apr 18, 2005 | 10:37 PM
SwiftShifter87's Avatar
Car: 1983 T/A
Transmission: 5spd
watch Smokey and the Bandit and look at the Antenna on that. Now think of a way to make that detachable when u don't want it there.
i personally plan on getting 1 too, i'm probably going to mount it on the Top where my whipper used to be, but i'll definitly make it removable.
Old Apr 19, 2005 | 08:27 AM
92RS3.1L's Avatar
Car: 91 Z28
Just get the antannea with a magnetic bottom. Works like a charm.
Old Apr 19, 2005 | 08:33 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
truckers talk on them constantly.
so if you're on a road trip, you'll hear them tell their buddys where they saw the cops. if you're doing 55, that doestn matter... but on a long trip, if you can set the cruise to 75 most of the time, you can drop HOURS off the trip.
plus its good on long cruises to talk to your buddies....
are you a professional moron or just a gifted amateur?
they make thoes with magnetic bases... works great for trucks and fbodys...... but it sucks for dem corvette folk.
Old Apr 19, 2005 | 09:14 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
I would like to see some factory-looking CB installs.
I have a handheld unit, but am looking to switch to something will be there all the time and I don't have to lug around.
So, running the antenna to the fender mounted antenna,...is this better than using the rubber ducky antenna? My range seems to really suck with the rubber one. And I don't want any 6 foot thing sticking out of my car.
Do they have a CB that will fit into the CD player slot?
Again though....I would like to see some more CB installs,...especially factory-looking ones.
Old Apr 19, 2005 | 09:27 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I used to have a CB in mine, and i used one of the see through window antennas, and it didnt pick up very good, although it looked good. But then i bought one of the magnet type and it worked very well
Old Apr 19, 2005 | 03:05 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
get a firestick.... my dad has a cb from when he was a trucker... its just under the legal power for the FCA.. the fire stick is way less than 6ft long and it is way more powerfull
Old Apr 19, 2005 | 09:00 PM
'86Twins's Avatar
Car: 1986 Pontiac Firebird
Engine: 305 LG4
Transmission: T-5 NWC
My father drove trucks for years. His brother always ran dual Fire Sticks, said they were the best of the best. My father always liked a single K40. One night when his brother and his brothers son were driving, he picked up a lady a LONG time with the K40 then the dual Fire Sticks did. Then again, the K40 is something like 6 or 7 feet tall.
Old Apr 19, 2005 | 11:02 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
well, my pappy still has his CB with all the tweaks he had done to it. i got it from him including a firestick and a magnetic whip.... im gunna stick with the whip for now... i dont really want the look of a firestick poking outa my car permanently
Old Apr 20, 2005 | 12:27 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
forget the cb radio and install a ham radio instead
Old Apr 20, 2005 | 02:25 AM
OutLaw305's Avatar
heh, better yet... two cups and aLOT of string
Old Apr 20, 2005 | 04:02 AM
smokefan's Avatar
thats great
Old Apr 20, 2005 | 06:30 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you are going to use CB's...
You gotta look cool when you do it, like this guy...
You don't wanna look like a total **** when you use it, like this dude...
Now -
Old Apr 30, 2005 | 08:49 AM
parks911's Avatar
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
You took the word right out of my keyboard.
Get yourself a magnetic base with either a wilson 2000 whip or a wilson 5000 whip.
I have been thinking about putting a CB in the car, but haven't really decided as of yet. I probally will since I have one in my Peterbilt.
Old Apr 30, 2005 | 09:42 AM
Demon355's Avatar
I'm also putting a cb radio in my gta. I have a Realistic TRC423. Nothing fancy but it does the job. Also getting either a K40 or this other one I saw at the gas station near my work. Going to put the antenna on the deck lid, right infront of my spoiler.
Old Apr 30, 2005 | 11:07 AM
hmmurdock_00's Avatar
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
I plan on getting one, just haven't found the style or a the best place to mount it. I am thinking of mounting in the same location Steve383 mentioned, decklid before the spoilier.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
