Painting Engine Compartment
Old Feb 13, 2005 | 03:35 PM
parks911's Avatar
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
I have been seriously considering changing the paint color on my 91 Camaro from the Artic White to the Rally or Millenium Yellow that most Caviliers have.
If I do this, I will want to engine compartment painted as well.
I will be pulling the motor & tranny out myself to have them rebuilt.
I was just wondering if someone could roughly tell me what a body shop would charge to paint it after I pulled the engine & tranny?
The heater boxes, wiring harnesses, & everything else would have to be removed by them.
I just want the engine compartment painted right now until I can get the motor & tranny back into it, then I will have the rest of the car painted to match.
Old Feb 13, 2005 | 05:43 PM
bitchin85camaro's Avatar
Car: 85 camaro
Engine: 327
Transmission: 350, 6200 stall, w/ brake
Axle/Gears: soon to be strange 5.14
just rattle can it your self flat black. thats what most guys around my area do with hot rods. it looks awesome no matter what color your car is black is always a good color for the engine compartment. as for paint the whole car its atleast 400-600 for materials. labor depends on who you know.
Old Feb 13, 2005 | 05:47 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Paint it yourself, a decent spray gun will run you less than paying a place to do it most likely and it isnt all that hard to remove the rest of the stuff.
Nobody here is going to be able to give you a good estimate because there are too many variables.
Old Feb 13, 2005 | 05:49 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Just rattle canning it black looks cheap and halfassed, not awesome, sorry. And materials can run from $200 if even that, to likely more than your credit card would like.
Old Feb 13, 2005 | 07:56 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I just pulled my engine/trans out today for that very reason. My car is going to the painter next weekend, but he's doing the whole car.
If you just want the engine compartment painted and not the exterior of the car, I agree with Z28Racer, do it yourself. The expense is going to be in the prep work involved- especially if your engine compartment is caked with grease. At the very least, do the prep work yourself.
Even if you've never painted before and you use a cheap gun like a Campbell-Hausfield from Wal-Mart, it's the engine compartment- it'll look fine. GM didn't do such a nice job under the hood either on most original cars I've seen.
Attached Thumbnails Painting Engine Compartment-c-documents-settings-kevin
Old Feb 13, 2005 | 08:18 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I painted my engine bay before I dropped the LS1 in.
I put a rust treatment on the rusted battery tray, used a pressure washer to knock alot of the caked on grease, then used the Castrol Super Clean (purple stuff) to degrease it all. I then re-sealed all of the seams.
I sprayed a 2-part sealer, base, then clear.
http://sethirdgen.org/ls1swap/ls1swapextbody.htm
Old Feb 14, 2005 | 11:43 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Most auto body places wouldn't take the job you're suggesting. They make more profit off insurance jobs so they won't bother the labor intensive job of removing and reinstalling heater boxes and wiring harnesses.
If you remove absolutely everything, you can get a place to do it. I was quoted $200 for a plain black paint, nothing fancy at all. I got it done body color instead at a custom auto body place for about $500. Look for a place that does hot rods/custom jobs. They'll be more willing to take on the job than the average collision shop and they'll probably do a better job too.
Old Feb 15, 2005 | 12:36 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I am for doing it your self. Just remember the beter you prep it the beter it comes out.
Old Feb 15, 2005 | 05:00 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
do it yourself. you dont have to remove any wires.
wrap them all in tin foil. its the best trick in the world. works great, fast, and its cheap.
Old Feb 23, 2005 | 03:03 AM
transram88's Avatar
Car: 88 Trans-Am 305 TPI, Yokahama dbs s2 front/ avs ES100 rear, Shift kit, K&N, complete 4th gen rear end, sun roof, 80's pinstripping, 4 point harnesses, memphis car audio
i just painted the TPI
Old Feb 24, 2005 | 07:42 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
This is with a Campbell Hausfeld special. Colors are GM metallic black, and GM metallic silver. Took the better part of a weekend to prep and spray. Why have someone do easy work, and get paid a bunch of money to do it? I'm talking about removing the wire harness and heater box here.
Attached Thumbnails Painting Engine Compartment-c-documents-settings-administrator
Old Feb 24, 2005 | 09:14 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Do it yourself with balck. I did mine with gloss black auto spray from P#p Boys and it came out great. It didnt look cheesy or cheap. Remember, you have that big ol hood covering the sun working to your advantage(minor imperfections will be hidden). Just clean everything up and scuff with light sandpaper and you will be impressed with the results. Practice on something to get the paint to flow evenly.
Thats why you got the car in the first place - so you could do the work yourself right?
POZ
Old Jul 28, 2007 | 10:47 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Re: Painting Engine Compartment
stage 20,
that's an excellent idea!
a lil tape at the junctions of the wires, and,,,
I like it!
Eric B
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
