Hatch Trim Project
Old Mar 13, 2005 | 11:46 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Hatch Trim Project
I thought I would share with you what did this beautiful Sunday morning. For some reason I was up at 7:15am so I decided to go outside and clean the glass on my Camaro. Once I got it cleaned I realized just how bad the trim around the hatch glass looked. I guess this is what happens when you don't drive a car very much :0( Anyway since the sun was going to be out I decided to do something about it. I masked off around the glass which took the better part of an hour to do. I used some fine grit steel wool and went over all the trim and put some real effort in to the rust spots. Luckily it looked a lot worse that was so it came off and got pretty smooth. I ran up to O'Reiley's and got a can of Krylon semi-flat Rust Tough paint. It went on really easy and the nozzle on it really helped control the over spray. I think I did about 3 light coats making the 3rd one a little thicker since the metal was getting hot and it helped it set up. As you can see the pictures pretty much tell the story. I have to say for about $6 of materials and two hours of time it was well worth it. Now I just need to get the rest of the car painted! Its 11:38am now... what else can I work on?
Old Mar 13, 2005 | 01:42 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Looks great! I getting ready to do the same thing and to the headlight pockets and trim and spray the inner fender area. Already did my hood and rear window louvers, fog light trim, and the front license plate trim piece, a month or two back. Made a HUGE difference. Used a couple of cans of Bumper trim black on mine.
Old Mar 13, 2005 | 03:45 PM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Since we seem to have a commonality here...
Here are some pics from when my dad and I did my trim two summers ago.
Old Mar 13, 2005 | 03:54 PM
Engine: LS1 V8
Thanks for the reminder John, I need to do my fog light trim as well. If the sun holds out I might do it this week. Its amazing what a little cleaning and spray paint will do for these cars. As they say... its all in the details.
Yours looks good Digital. I see you actually primed yours and then painted it. Only time will tell if I should have done mine that way.
Old Mar 23, 2005 | 07:30 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Looks great, I'm getting ready to do the same as well as the outboard trim on my ttops. Keep that thing looking sharpe!
Old Mar 24, 2005 | 01:11 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Welcome to day 1 when I bought my car. First things I did:
that trim
t-top trim
repainted headlight bezels
door handles and locks
Old Mar 24, 2005 | 04:05 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
i had to do the same thing , i bought a defrosterless hatch and it was bad, i did it off the car though so i could do it right and get it perfect. We sanded a lot and then use SEM high build primer surfacer , and then sanded in between coats , and then used SEM 39143 trim black . The stuff cost like 15 bucks for both cans but it works great . The only thing better is the stock finish on my original hatch glass.
Old Mar 24, 2005 | 09:50 PM
bitchin85camaro's Avatar
Car: 85 camaro
Engine: 327
Transmission: 350, 6200 stall, w/ brake
Axle/Gears: soon to be strange 5.14
u guys got me motivated to touch mine up it probably feels good not having to look at that rusty trim hahaha
PurelyPMD
May 5, 2016 04:57 PM
punkmaster98
Sep 30, 2015 11:01 AM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
buckshot63
Sep 3, 2015 08:10 AM
