Factory Fog / Driving Lights
Car: 1992 Camaro RS Convertible & 1983 P
Engine: 305 TBI & 305 4 BBL & 4.7 liter
Transmission: Auto & Auto & 5 Speed Manual
On the cars that came stock with driving lights/fog lights in the grill insert, I wanted to know what size the lights are. Are they fog lights or are they driving lights? What was the wattage?
Any amplifying info will be appreciated!
shipfitter
shipfitter
HELLO
What I want to know, in case I confused anyone is this:
Camaro grill insert (IROC & Z28) the black grill piece that replaces the stock traditional looking grill on RS's and plain jane Camaro's. This is the piece with either the red bowtie or silver lettered "Camaro". The lights that are in THAT grill insert!
1) Fog lights; or
2) Driving lights?
3) What is their size, ie, 5" x 9"?
If some one would please step-up and volunteer some information, I would be grateful.
Thank you,
shipfitter
1) Fog lights; or
2) Driving lights?
Thank you,
shipfitter
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Well since no replies..
I think the factory lights are ugly. They are too big and like most factory fog/driving lights they suck.
I purchased the Z28 grill from Chevy and mounted PIAA 1500XT driving lights. These lights were around $200 but worth it. They are just about as bright as my H4 headlights, but the beam pattern has a very sharp cut off as to not blind others. The lenses are glass and sealed very well. They've been on for many years without any condesation. Most of the cheap aftermarket autozone apc type lights I've seen are garbage. I would go with quality Hella or Piaa driving lights. There is more driving than fog, so I would go with a driving type.
I am sure that the factory lights are not "cool" and are probably highly inefficient compared to after market specialists.
I have the RS grill. I want the IROC/Z28 grill. I want to fill those holes with a driving light, just like they came from the factory.
But, I want to know what size are those lamps from the factory, so I have something to compare against (size-wise) when looking for aftermarket lamps.
Just some info, please! But, thank you for replying anyway. It is appreciated.
shipfitter
shipfitter
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
go to your local parts shop (autozone, advance, ect.) or even walmart- look for the fog lights- i got a set of Blazer OEM series fog lights- they look pretty damn close to the origional thing- most people cant even tell they are a set of 20$ lights made my RS look ALOT better.
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Car: 88 Camaro
Engine: L98 350
Ditto here. My old original fog lights were rusted out bad and one had a lens cracked. The $20 Blazer lights were near identical looking to the stock ones. Just had to cut ends off the wiring and tie into new lights.
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Sorry to wake up an older thread.
The cut-out size for the fog lights is 4"x8" but the fog light is mounted on the bumper bracket behind the cut-out. So you can put any size fog light in there that would fit on the bumper.
I agree with going aftermarket, mainly for the selection and also price. I do not think paying $80+ for each OEM light is reasonable. But that's just my opinion.
I've been looking at fog lights for some time and so far the best fitting lights I saw were 6-1/2"x4" Cyber White (by Navigator). The rest of aftermarket fog lights are smaller (4"x2" or 3"x1") and that would leave ugly gaps in the cut-outs. I found some German 4"x8" lights but will have to look at the bumper tonight to make sure they will fit before I can purchase them. Sure would be nice to have perfectly fitting aftermarket lights on the car! Will keep y'all updated.
Lou
Lou
Car: 88 Camaro
Engine: L98 350
Factory lights vs the Blazer $20 lights. To get the better lens you need the actual yellow fog lights and switch lens with the clear driving lights. The yellow is in the reflector. Couldn't afford both sets myself but might change them someday. Factory lights here:
This Is Good........
.......reviving old threads. Thats okay, because this project is ongoing for me. I have all of my parts now, just that the weather is cold, wet, and rainy up here in Maine.
I have after market driving lights (5.5"x3") w/blue crystal lenses. Factory fog light brackets, fog light switch, and aftermarket harness, factory grill w/"CAMARO" in silver.
I will post a pic after I get it done, weather permitting!
Steve
Steve
Engine: TPI
Found some 4"x8" fog lights on eBay, new ... for $25, not too shabby. Will be buying them now and try to install them within a month or so. They will fit perfectly and not leave any ugly gaps.
Can't wait!!
Can't wait!!
Car: 88 Camaro
Engine: L98 350
Might keep in mind that a lot of these cars draw intake air from the grille openings around the fog lights, have ducts up to the filters. Probably not a big deal but something to look at. The aftermarket lights look decent on the car for not much money. Picture of mine on car:
Car: 85' IROC & 87' IROC conv
Engine: Both have Vortec TPI 350
Transmission: T-50
Axle/Gears: 3:42 & 3:73
OEM Fog/Driving light measurements, outer Black Metal Trim 2.9" X 5.6" Lenses 2.44" X 4.7" there are left and right lights angled lenses. GM # Left 5974579 # Right 5974580 still available.
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Originally posted by tom3
And aftermarket lights here:
Sorry for bringing up an old thread but are those lights in that picture mounted on brackets?
Because I wanted to know if anybody has any ideas as to how I could bolt on the blazer lights seeing as how my car did not come with fog lights originally.
Car: 88 Camaro
Engine: L98 350
I just mounted these lights on the plastic grille piece, drilled a hole for the stud on the light bracket. These lights are pretty lightweight, no vibration or shaking that I can notice.
Car: 1985 Camaro
Engine: 5.7, Vortec heads, Headers, TBI
Transmission: Built 700R4
Axle/Gears: 3.23 BW 9-Bolt Disc Brake
hey black84z28-4spd what type of headlight conversions do you have and what bulbs are you running in them and also what type of fog lights are those too thanks
Car: 1990 Camaro RS
A buddy of mine at work who actually does know alot about 3rd gens commented "why did you spend over $300 to get those put in"? When I told him about the blazer lights, he almost crapped himself because he did an all GM conversion on his old 92 RS and it cost him over $300.
Car: 1992 Chevrolet Camaro RS
Engine: 5.0L (305ci) TBI V8
Transmission: 4-Speed Automatic O/D
Axle/Gears: 9-bolt Borg Warner, 3.70 posi
I agree: those Blazer lights are quite good and they look just like the stock GM lights.
Here is a picture of my car with the Blazer driving lights:
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
ive got blazer fogs in mine they look really nice. i got some pics of them on my cardomain.
Car: 91 RS
Axle/Gears: 10 bolt
I used the fog lamps they used to put on the old AMC eagles and spirits. I like the fact that they come with plastic covers to protect the lenses when not in use
There are some very distinct differences between the factory lights and the blazer aftermarket lights...
1. The factory lense is built on an angle in relation to the housing. In order to install the blazer lights and make them look right, the housings have to be pointed "crooked".
2. The mounting system for the blazers is completely different. You can fabricate your own brackets... but it isn't as clean as the factory setup.
From 20 feet away.. maybe they look identical.. but anyone who knows what they are supposed to look like will notice right away.
Engine: TPI
Originally posted by johnyIROC
From 20 feet away.. maybe they look identical.. but anyone who knows what they are supposed to look like will notice right away. [/B]
Lou
Car: 1990 Camaro RS
Originally posted by BigBabyLou
I agree. But it depends on each owner what they prefer. Stock look from close up for lots of moolah or stock look from distance for much less. And who will be able to tell if they are stock fog lights or not? Only us!!
Lou
Lou
Its only obvious they arent stock to me.
They look stock to everybody else, especially at night.
I just couldn't see spending $300+ for all the hardware just to say "it's stock man".
I'm just a cheap ***... that's why.
Don't get me wrong... there is nothing wrong with saving some money on the aftermarket ones... I just kept seeing people posting that they "look 100% stock".. etc... and they really are not the same at all other than the general shape.
Car: 1988 Pontiac Formula 350TPI HARDTOP
Engine: 04- 350 Crate Motor with Crane Cam
Axle/Gears: 10 Bolt Posi 3.73:1
Fog Light 3RD Gen. Mod ?
Has anyone here ever Seen a 1988 3RD Gen. Factory NON EQUIPPED Formula with the Fog Lights Cut into the Front Bumper Inserts as a Mod ? Just Wondering if any 3RD Gen. Owners tried that one .
He...He.... Or How About this 3RD Gen. Mod ................
Interior Manual Mirror Control Joystick for the PASSENGERS SIDE <>? Has Anyone here Tried that One Too ?
I Mean , if you could put a Notchback on a 3RD Gen. F Body , then anythings POSSIBLE , Right ?
US PONTIAC Dudes Gotta Look GOOD Too !
Car: 91 T/A, 79 T/A
Engine: 305 TPI, '68 350 Olds SC'ed
Transmission: 700r4, 350 Streetfighter
Axle/Gears: stock, 3.42
The foglights on my '91 don't light up. I turned on the switch, and the light on the switch lights up, but my foglights don't light up. I wonder if it is burned out bulbs or a connection problem, because I really want them to work.
