1A Auto...
Old Apr 13, 2005 | 01:23 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
1A Auto...
i just got my front carpet for the RS & i got it installed & i must say i wasnt too happy with the product.i had to cut & cut & cut pieces of the carpet off to make it fit right & even after all that it still doesnt fit "perfect".....the company was fast & good to deal with but the product sucks!
anyone have problems like this?
Old Apr 15, 2005 | 09:30 AM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
I bought a shifter boot from them one time. I had to modify it to make it fit, and even then it didn't look right.
Old Apr 15, 2005 | 10:14 AM
CaysE's Avatar
Are you sure you didn't end up with a 4th-gen carpet for some reason? Carpets are usually cut-to-fit anyway, but from the sounds of it, you may have received the wrong piece.
Old Apr 15, 2005 | 11:09 AM
Engine: 283
my luck i probably did! i guess sometime waaaaaaaaaay down the road ill have to redo it,but for now itll due. i know one thing though,i wont be ordering NOTHING else from this company! well you live & learn.
Old Apr 15, 2005 | 07:51 PM
ace16a's Avatar
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
I bought a turn signal lever w/ cruise and a rear hatch weather strip. the turn signal lever fell apart after two weeks and the weather strip leaked worse than the wore out original.
Old Apr 18, 2005 | 05:47 PM
Kandied91z's Avatar
Re: 1A Auto...
there is no such thing as a direct bolt in product when it is in fact aftermarket. ACC, 1aauto and the rest all use the same style carpet mold. it takes practice that's for sure and definately need to cut up the carpet some to fit perfect but that's why the extra length is there. even with the transmission cutout option there is still alot of work invovled but if you take your time and do it right it's worth it.
the molded carpet available. particularly the stock 800 count is not the best carpet out there but it is a direct replacement and for the price very good carpet. now you personally may have had bad carpet but i had to do alot of work making mine perfect with the cuts which was time consuming but worth it.
so is it the carpet itself is of poor quality or did you not like the fact that the carpet didn't just lay in place and be perfect with no work?
Old Apr 19, 2005 | 09:49 PM
Engine: 283
Re: Re: 1A Auto...
i hope your not meaning that the way i took it??
well i aint that d@mn dumb to know that there is gonna be work involved in putting carpet in.live & learn.
Old Apr 19, 2005 | 10:33 PM
CaysE's Avatar
I know both of you know what you're doing, so let's not get out of hand; it's just Internet communication, it's hard to gauge the meaning behind what people say.
As far as the vendor goes, 1A has usually been pretty good. I would talk to them just to let them know what happened and see if you possibly got sent the wrong piece. Carpets always involve some measure of work, but it should at least lay correctly within the mold of the floor pans.
I'm going to move this to Body & Interior to see if anyone can help or has experience with carpet orders from 1A.
Old Apr 20, 2005 | 12:01 AM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
I just ordered the turn signal lever yesterday. I hope I have better luck than you did.
Old Apr 20, 2005 | 12:23 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
hey kandied91z weren't you looking to replace your carpet with a 1500 count. if you did what was the name of the company that you purchased it and price. as far as aftermarket products go i have to agree with kandied on that one cause i have seen all sorts off "direct bolt on parts" and they fit like my crap. i had to do lots of mods to the dumbest things out there so carpets are no exception i guess.
Old Apr 20, 2005 | 11:17 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
i used acc carpet last summer in the trans am. i realized replacing carpet is a lot of work. doing minimal work due to the fact that the car is by no means a show car and i didn't feel like spending a rediculous amount of time on it, i was able to get it "good enough" it's not acc's fault that the carpet does not lie completely perfect, much the same as why it's not hawk's fault if you can't just slap on a 5" spoiler and have it perfect without any work.
Old Apr 20, 2005 | 11:30 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
I got mine from them and it just fell into place, had to trim on the sides for the door sills and open the hole a little for the console area but that was it..... took about an hour...
I also got my seat covers from tham and I am very pleased with everything, door seals, hatch seal
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I have their carpet and turn signal lever. The lever is as original and works perfectly. The design by nature for them is flimsy and absolute junk thanks to the General and mine is holding up as well as an OEM would.
The carpet always has to be slightly modified to fit no matter who you get it from. Even an NOS one thats been boxed for some years will take some time to conform. The carpet is best applied when it has been in the sun for some time and gotten hot. People often skip this step. A friend who does upholstery work steams the carpet slightly which he says helps but I've never tried that. I am very happy with both of their products.
Old Apr 20, 2005 | 12:28 PM
Engine: 283
thanks CaysE for moving this here! maybe ill get better responses....
Old Apr 20, 2005 | 12:30 PM
Engine: 283
thats a good tip!! wish i wouldve known it sooner-lol. ill keep it in mind if i ever do another one
thanks for the responses guys!!
Old Apr 20, 2005 | 01:01 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
I don't like their outer window sweeps at all. Got their T-top headliner, and am not happy with that either. Doesn't fit right around the tops. I'm 0 for 2, and there won't be number 3.
Old Apr 20, 2005 | 04:29 PM
Kandied91z's Avatar
well i couldn't find any company that made a molded thirdgen carpet over 1,000 count. i'm still trying to find a shop in the great lakes region that can custom make the carpet i want and fit it so we'll see..
the 1,000 you can get from any of the companies like ACC and the rest. highly recommend it as had i known about it i wouldn't have gotten the 800. it's not only a finer grade with a tighter feel but it doesn't shed as much.
Old Apr 20, 2005 | 04:57 PM
smokefan's Avatar
thanks kandied for the info on it. i would like to replace it after the summer is over. it still looks ok but i guess i am too pickey didnt a magizine just do a small write up on your ride??
Old Apr 20, 2005 | 05:01 PM
Kandied91z's Avatar
they are all below..
Old Apr 23, 2005 | 12:00 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
same thing happened to me.
Old Apr 28, 2005 | 02:45 PM
MR.GTA's Avatar
Car: 1991GTA, 1991 Formula 350
Engine: L98/ L98
Transmission: 700r4, ditto
Axle/Gears: 3.23 x 2
1A auto is good to go! I bought carpet and a power window motor from em, I've had the motor in now 3 years, still works like new. As far as the carpet, well........it still looks good sitting in the box............ lol. Shipping could be a little faster though. Price wise they are excellent on quite a few items.
Old Apr 28, 2005 | 11:07 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
I was happy with their 1A carpet. It did take soem work to get it in. I had to cut the center console hole a little wider and cut the oles for the seats and the seatbelts. If you have a SHARP knife or better yet, a good razor it makes the job easier. Another trick I used was to use carpet tape and my steam iron, set on rayon to "iron" out the high spots. There were a couple of wrinkles that just would not lay down but I hit those spots with double sided tape and the iron and down they went. That insulation was a Bear to cut through. The only worrysome thing with those aftermarket carpets is that the padding/insulation is thin and only covers about 5/8ths of the area that stock padding covered. I pulled the old padding from the origional and sprayed adhesived it to the floor pan. Then I put the new carpet down.
happyhapka
Mar 30, 2015 03:45 PM
TIMMYS89GTA
Apr 26, 2014 08:27 AM
travisgold
Jul 21, 2013 07:39 PM
lopezstud87
Jan 6, 2012 06:45 AM
racerquinny
Aug 4, 2011 08:24 PM
