Body Modification Ideas... need opinions
Old May 2, 2005 | 07:58 PM
(BR)G-Machine's Avatar
Well, I dont know about anyone else, but I really dont like the huge square turn signals on the front end. I think the whole frontend would be timeless but those... I dunno. Anyhow I just finnished up my 2nd year of Industrial Design, and now I have the skills to change some of this stuff, and work towards a design of my own. Plus body mods are the only thing to do when your flat broke
I was thinking of cutting out the parts around the turn signal, vacuum forming some plastic, and welding it in place. So that there would be 2 intakes there. Make it look a little more modern.
Or just fill them and move them up to the headlight cavity, like in the sketches.
Or fill it and add something smaller and round in it's place.
Here are some exploration sketches I was doing. Should give a better picture:
Old May 2, 2005 | 09:25 PM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
love the intakes....don't like the turn signals though. They look way out of place, like an after thought. I think the fact that you made them round is what hurts them the most. Our cars dont have anything on them like that. Can you incorporate them at all into the headlights? Do you have inspection where you live? If not, you can just leave them off.
Old May 2, 2005 | 10:00 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Love the air inlets, but maybe have 3 lights in the headlights instead of two? Like 3 blocks?
Old May 2, 2005 | 10:05 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
If it was me i think using the turn signal pockets for air ducts is a cool idea. But i dont think where u put the turn signals would look good. I think if u did a custom grille in the center and but the turn signals behind the grilles would look 10 fold better. just my .02 cents
Old May 3, 2005 | 12:06 AM
You couldnt be more might about the circular element, when the entire car is rectilinear... ie quare, angular.
And the lights behind the grill would be stealth!
Man this is why I like coming to you guys; keep the ideas coming and Ill whip up some more sketches tommorow.
Old May 3, 2005 | 12:13 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You guys ever get that crusty crap in your eyes when you wake up in the morning? Those first round singals look like that stuff.
The ducts look awesome, though.
Old May 3, 2005 | 09:14 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I was thinking the same thing!
I really like the rest of the drawings though. Very nice creative work!
Old May 4, 2005 | 01:04 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i agree with the air damns....if you want to stir people up make a headlight conversion using projector lights
Old May 4, 2005 | 01:30 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Use a dual filament hi/lo headlight bulb (from a firebird) then have the other housing the turn signal. Problem solved.
Old May 4, 2005 | 10:47 AM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
The firebird lights are too big, aren't they?
Old May 4, 2005 | 11:11 AM
bnoon's Avatar
Yes, they're quite a bit larger than the opening for the Camaro lights. Do they make dual beam ones small enough? Dunno...
Old May 4, 2005 | 02:07 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Isn't one of the maro lights a dual filament? That's the same size as the later 91-92 bird headlights anyways.
Old May 4, 2005 | 04:58 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
no, camaro headlights are the same with a single filament. when you hit the brights the inner light just come on as well.
Old May 4, 2005 | 06:30 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
In addition to the outer one or does the outer one go out then?
Old May 4, 2005 | 07:56 PM
hmmurdock_00's Avatar
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
love the idea with the air ducts being in the turnsignals, but I believe someone has done it, not sure if they moved the signal yet.
You could go somewhere buy a exterior lamp to you liking(i think a clear lense be best) place in a orange light and place it in the grill like the 65-67 GTOs had. Old school, but still goes with the camaro, also if the housing was small enought you wouldn't lose much air air intake if any at all.
Old May 4, 2005 | 09:15 PM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
So how exactly would you go about putting these vents in? This is a question solely for the thread starter, but for everyone. How would you make a body modification like this using our front bumpers. Is it something relativley simple...can you do it to an existing bumper, or do you need to create a new mold...would it be extremely expensive? It is something I would like done, and would definetly pay for it if it was practical. So what is everones opinin?
Old May 4, 2005 | 11:26 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
When u hit the hi beams u will have a total of 4 headlights on in a camaro.
Old May 5, 2005 | 01:55 PM
I was thinking you could do it a few ways.
1) Modify and sculpt a stock front facia, and then make a firbreglass mold from that pattern. But this is tricky to get to fit right and mounting it on the car.
2) Make a wood mold of just the vent section you want. Vacuum form it out of plastic (preferably urethane but I dont know if urethane vacuum forms well.) Weld in the sections, or bond them if it isnt urethane.
3) Make a 2 sided mold, and thermoform urethane sheet. Weld in the sections.
4) Find the events you want on another car with a urethane bumper, and with enough luck, weld them in.
The bumper isnt gonna hold up forever, not like a stock bumper cover. But should be okay.
Old May 5, 2005 | 04:41 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Sketch looks cool, but I agree with the turn signals. Just do an H4 conversion on the outer headlights and, as mentioned above, use the inner space for the turn signal. You could even put a grille there and put a hidden turn signal behind it
Ken
Old May 6, 2005 | 01:26 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
As for the turn signal, I like the idea you sketched on the far right, in the middle. That circular pattern looks cool.
Old May 6, 2005 | 09:02 AM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
What about something like a row of LEDs below the headlight pocket?
Vintageracer
Jan 10, 2020 05:33 PM
TheTraut88
Sep 11, 2015 05:16 AM
angel2794
Sep 8, 2015 06:22 PM
TheTraut88
Sep 7, 2015 05:22 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
