power hatch problem
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
power hatch problem
I need a suggestion on what I broke on my power hatch. The hatch clicks, and locks, but the motor doesnt pull the hatch down. It makes no noise or anything. What should I look for?
Car: 1987 IROC Z
Engine: 350 TPI L98 block
http://top-downsolutions.com/
Get a motor
gear nut
housing (ebay the housing, search for pull down motor and you will see the casings like these
http://cgi.ebay.com/ebaymotors/ws/eB...category=33656
NOS Striker Sensing Switch, 1988-91 hatch pull-down unit
Aftermarket Nylon Guides for 1986-91 F-Body Hatch Pull-Down Unit
You may not need all of these parts immediately, but let me tell you from my own recent experience, just get them now. This is not a job you want to do again in the near future. Most of the parts mentioned are going to be damaged already anyway. Plastics from the 80's were not meant to last. I've got to commend Lon over at Top down solutions, everything I ordered got to me in 2 days flat (from california to texas) and it was all good quality stuff. You cant really go wrong with em.
Get a motor
gear nut
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Check the pulldown fuse first. In my 89 Formula, it was in a seperate fuse-holder, near the fuse block. It looks a bit like one of the add-on ones you get from a parts place, and takes a 15A fuse.
Car: ‘92 Z28
read this post.
https://www.thirdgen.org/techbb2/sho...ighlight=hatch
If the motor won't run, the striker switch is most likely shot.
If it were running and not pulling down, then the gear nut is the most likely component to replace.
The pos above will tell how I tested mine.
I have replaced the gear nut, striker switch (2x), and the reversing switch in mine at different times. I learn a little more each time I take it apart
. Trending Topics
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Re: Pull down parts
Originally posted by Redbird87
My 2 cents-- Lon at Topdown has great parts and was most helpful when I did mine
Car: 89 firebird GTA
Engine: 350 T.P.I
Transmission: 700-r4
mine does the same thing I just hit the switch with something a few times and then it will work. the the panel off hiding the motor and hold the switch by the latch and just tap the stirker switch with something and see if it does anything
