any pictures of a rear mounted battery?
Old May 18, 2005 | 06:49 AM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
Transmission: TH700 R4
Axle/Gears: 3.08 drum
as the title says, does anyone have pictures of a battery mounted in the back hatch area? i'm trying to figure out where to put mine while saving room for the subs and amp.
Old May 18, 2005 | 09:58 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Spohn sells a kit to mount it in the spare tire compartment. i think its spohn.
i want to do that , but not sure how and where to run the wires....
Old May 18, 2005 | 02:14 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
i got a kit from summit already, just not sure where i wanna put it.
Old May 18, 2005 | 02:52 PM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
why would you want the battery in the rear? just woundering
Old May 18, 2005 | 03:21 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
weight distribution...essentially, because the engine weighs so much, often times a car is nose heavy, having a closer 50/50 weight distribution between the front and rear wheels will enhance handling, and feel for the road.
Old May 18, 2005 | 05:49 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
It also helps when installing an SLP CAI , airbox needs to be where the battery is.
Old May 18, 2005 | 06:21 PM
Car: 1997 S10
o cool thanks for the info learn something new every day
Old May 18, 2005 | 10:09 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
no pictures yet?
Old May 19, 2005 | 05:55 AM
carfixxer's Avatar
Car: 87 GN & 87 T
Engine: 3.8 V6
Transmission: 200r4
How much do those kits cost? I want to put it in the rear on the driverside under the cargo box compartment. Need room for giant K& N that the hood is crushing.
Old May 19, 2005 | 02:04 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
i think my kit was around 50, 60. its essentially the wires, a case, and some mounting brackets
Old May 20, 2005 | 03:04 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
You are better off mounting it to the rightside of the car, that puts the weight over the right rear tire, for better traction.
Old May 20, 2005 | 04:51 PM
carfixxer's Avatar
Car: 87 GN & 87 T
Engine: 3.8 V6
Transmission: 200r4
I know the optimum location is rightside but I am not one to temp fate by not carrying a spare tire. I dont have that inflatable compact spare crap either I got a temp spare off another GM car.
Old May 21, 2005 | 08:41 AM
Car: 1971 Camaro
Engine: 427
Mine is going on the highspot, on the passenger side. Outside of the spare tire well. The top of the battery box will be just under the hatch lid. Not hid, but it takes up little useless space.
Old May 21, 2005 | 01:00 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
does anyone think it would be unwise to put it in the bottom middle of the trunk area, on the right side under a subwoofer box? Or should I be concerned about ventination at all?
Old May 21, 2005 | 01:52 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
the battery shouldnt have ne problem in the trunk any where, it is alot cooler then in the engine bay
Old May 24, 2005 | 10:51 AM
Car: 1971 Camaro
Engine: 427
Must be vented outside car. Esp. to be track legal.
Old May 24, 2005 | 03:24 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
With the exception of sealed batteries such as Optima's.
Old May 24, 2005 | 03:52 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Another idea is to use two of the 6v Optimas, and wire them in a
series to get 12v. They would be very flat, and would fit in the
spare tire area easily.......
Old May 24, 2005 | 04:29 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
I guess I'll be the first to post some pics. I didn't get a kit, in fact I didn't know they made one. just got a piece of wood and cut it to fit in the spare tire compartement. Got 2 long bolts and put throught the wood and made a bracket to hold the battery down. I ran the cable over the wheel well up to the front of the car and the negative I just put through a hole in the bottom of the tire compartement and fastened it to the frame. I also have my starter solenoid back there also. My battery is an Optima by the way.
Old May 24, 2005 | 04:30 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Here's another.
Old May 24, 2005 | 04:31 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Here is it closed.
Old May 24, 2005 | 04:32 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
sorry...
Old May 24, 2005 | 11:49 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
do you keep a spare tire in the car?
Old May 25, 2005 | 05:49 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
no
Old May 27, 2005 | 12:49 PM
Car: 1971 Camaro
Engine: 427
88 WS6 TransAm GTA
NHRA does not consider a sealed battery as safe. Therefore, it still must bew contained in a sealed, vented box, unless it is seperated from the driver by a firewall.
Old May 27, 2005 | 12:51 PM
Car: 1971 Camaro
Engine: 427
1982TA,
Nice install, but again, not track legal. Battery must be mounted on plate steel.
Wood is not legal for track use.
Old May 27, 2005 | 01:46 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
wish I had a working camera, I run a BMR 4th gen rear mount tray on the left side of my rear well, drill a few holes and it bolts right in. Has a red top optima sitting in it with a nylon tow strap holding it down.
Old May 27, 2005 | 03:04 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
ok, here we are
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Elliswon
Aug 10, 2015 12:33 PM
