front lisence plate bracket warps nose?
Old Jul 7, 2005 | 11:11 AM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
So i got in an accident and the shop I went to replaced the nose and put a lisence plate bracket on the nose, which warped the nose in on one side abit and out on the other. Took it back in this morning to complain and he said they won't fix it ever tho all their bodywork is supposed to be guaranteed. He told me that that always happens when mounting on a poly/plastic piece. whatever the nose is made out of, I dont know. Which I'm pretty sure is BS. I know most people don't have front plates, I don't want them either. But anyone who does have fron plates, and who doesn't have a warp in the nose, could some people post a couple pics, so I can print them off and show as proof to this guy that their repair crew was at fault for this? Thanks. I'm going to post a pic in abit to show the warp.
Old Jul 7, 2005 | 11:20 AM
Car: 88 GTA
heres a pic of the nose
Old Jul 7, 2005 | 05:03 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
sorry to say,...but the guys at the shop are right.
I used to work at a couple different body shops, and always hated putting the front plate on the newly repaired front ends of cars like these... screws them up every time.
That's why when I repainted my car and my brothers firebird, I left the front plate OFF.
Just have to deal with the occasional hassle from the "man"
It looks like the scews that were used to attach the plate mount, is what has caused the damage, and that is to be expected, when dealing with these urethane bumper covers
Leon.
Old Jul 7, 2005 | 09:02 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
looks like you tightened them way too much
you should just go until there is light tension and then adjust each side accordingly so the plate sits straight, its plastic man
looks like you just tightened them each all the way one at a time then was like "damn, that destroyed my front end"
Old Jul 7, 2005 | 09:37 PM
Car: 88 GTA
i didnt touch it. it was the guys at the body shop. I know it can't always happen, cuz my nose from before the accident wasn't warped like that.
Old Jul 8, 2005 | 12:36 AM
firerider76's Avatar
Car: 1986 Trans Am
That's a shame but there is a remedy while staying legal.
Just get a license plate bracket that mounts on the underside of the nose. Then you'll never have to worry about it again.
Old Jul 8, 2005 | 12:37 AM
Car: 1986 Trans Am
another shot
Old Jul 8, 2005 | 01:17 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
i took the plate off my gta, the nose is all warped like that...looks like crap but it looks alot nicer and is harder to see than a white rectangle.
Old Jul 8, 2005 | 09:20 AM
Car: 88 GTA
i think i might just put the plate back on. The car is white and plates in BC are white with blue digits. So at least it kind of blends in. Oh well, one more thing I can't get a ticket for.
Old Jul 9, 2005 | 02:55 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
how did you find a plate bracket like that ?
i plan on having none, less i find a way to connect to to frame of bumper like that and not through front of it,
thanks
Old Jul 9, 2005 | 10:41 PM
Car: 1986 Trans Am
I snatched it on ebay. There was a guy that had it built up for his TTA cuz he didn't want to into the nose. He had them made up at a machine shop. Made 12 of them(it was cheaper that way). I wound up picking it up for like $15 I think. I couldn't pass it up.
Old Jul 9, 2005 | 10:42 PM
Car: 1986 Trans Am
If you would like I can measurements of it and post them. You could probably fab it up yourself.
Old Jul 10, 2005 | 11:53 AM
Car: 92 RS
Engine: a slow one
That's messed up that they did that, I would definitely be pissed.
All it takes is common sense as your putting it on to see that something is not right.
They should have put a little silicone on the screws and just put it on snug enough so the back of the plate puts a LITTLE bit of tension on the point of your bumper, then adjusted the screws on the left or right side to sit the plate straight without it being tightened too much.
The silicone will keep the screws from vibrating out since you don't want to tighten them too much.
Worked great on my bros firebird, and it didn't warp anything.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
