91-92 Z28 guage panel
Old Jul 13, 2005 | 10:49 AM
88drop's Avatar
Car: 88 Camaro Convertible
Engine: anemic but fuel effecient 305 Tbi
(1-2 Z28 guage panel
HELP! Was wondering if any of you knowledgeable thirdgenners can tell me if when purchasing a used 91-2 Z28 guage cluster, should I be concerned that the speedo & tach needles are not on zero (when not installed)? I bought one already out of car & mph needle is like on 45 or something. I apreciate any info U all can give me.
Old Jul 14, 2005 | 04:37 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
I have bought several that were not on zero when unplugged. they worked fine
Old Jul 14, 2005 | 03:30 PM
88drop's Avatar
91-2 Z28 Guage panel
Thanks for info 911Rsq
Old Jul 14, 2005 | 04:46 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
just checking
are you putting those gauges in ur 88 convertable? if so.. U are gonna need to do a VSS swap in ur 700r4, if i am correct.. anyone confirm this please?
Old Jul 15, 2005 | 03:35 PM
88drop's Avatar
91-2 Z28 guage panel
Yeah, I am hoping 2 put in my 88 vert. (which currently has stock 115mph speedo) & later also plaan to get some of those coool looking reverse indiglo/white faces-probably should do that b4 mounting in car, huh? Excuse my ignorance but what's the Vss & how who I acess it? Thanks for info.
Old Jul 16, 2005 | 08:06 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Have you even tried mounting a 90-92 panel in your dash ? You DO know its nowhere near a direct bolt in fit up perfect easy type of deal right ?
Old Jul 16, 2005 | 09:38 AM
88drop's Avatar
No I hadn't tried yet-oh well when there's a will, there's a way (I guess it's fabrication time ). Thanks for heads up *****.
Old Jul 16, 2005 | 09:39 AM
88drop's Avatar
Z28 guage
That was "thanks for the heads up, R I C E R
Old Jul 16, 2005 | 11:18 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
About the most reasonable way is to swap the whole 90-92 shell in there, IMO it looks much better with its less squared lines.
To do this you need the shell from a 90-92 , the metal end brackets which you remove by drilling out spot welds on them. The gauge trim bezel from a 90-92. I've done the swap in 5 thirdgens. Quite a nice upgrade I think...
Old Jul 18, 2005 | 03:41 PM
88drop's Avatar
Well, picked up another one yset. (along w/several other goodies) & to my surprize, he gave me the entire dashboard w/a bunch of wires & "Z28 " badge to beat. So when I get some time to look it over in detail, (or more likely tire of it sitting in the apartment ) I'll try to get it in. Have you ever installed any of those white faced, reverse indiglo gauges in a Z28 dash?
Old Jul 18, 2005 | 03:42 PM
88drop's Avatar
Z28 guage cluster
oops: that was I picked up one yesterday.....
Old Oct 8, 2005 | 03:19 PM
88drop's Avatar
91-2 cluster swap
Hey R i c e r,
I was just reading Ur reply above & was wondering about the metal brackets that needed to be drilled out of I assume the donor Z28, will it bolt up to the bracket in my 88 & have U ever installed any of the reverse glow white faced guages? Also do U have any pics of any of the swaps U've done-maybe like a b4 & after? Thanks in advance 4 Ur time & wisdom.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
tglennon11
Sep 23, 2015 05:30 PM
Stryker412
Sep 7, 2015 09:11 AM
andy74
Sep 3, 2015 08:41 AM
