Windshield Fix?
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Windshield Fix?
I got the bottom of my windshield busted up pretty bad, What can i do to keep it from spreading. It doesnt have to look good just need a temp fix.
Car: 88 Trans Am
Engine: 305 TBI
Chips in windshields can be fixed by many different companies that squirt a liquid into the glass then vacuum seal it.
Larger cracks cannot be repaired. You run the risk of having the crack go completely across the windshield, separating into two pieces. It can be very dangerous at high speeds.
Your best bet, if you can do it yourself, is to buy a new windshield and install it yourself. It should run you about $300. If not, many auto places can install a windshield (if they have it in stock) in an hour or two. The labor will cost you more.
You can risk the crack getting bigger for a day or so depending on driving, weather and road conditions. However you should have the windshield replaced ASAP.
Car: GTA
Engine: 383 HSR
Its broke down by the black strip on the bottom its mutiple cracks. Think maybe some weather tape the metallic kind will be a temp fix for a while? or some rtv?
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
OUCH.. $300? Around here companies will put it in for less than $230... i've heard claims of ppl on here that have gotten brand new windshield glass for like $130-$150 and installed it themselves (the installation materials are CHEAP.. like $10-$20)
Car: 88 Trans Am
Engine: 305 TBI
Wow, I have heard cheaper than $300 also but I've only ever replaced 1 windshield and that ran me the three hundred. It was for a 90 Firebird too. ::shrugs:: Guess I got ripped.
For multiple cracks against the stripping, you could probably get away with some tape for a short time. The first rain may not peel it away, but the sun will dry it out then the rain will cause it to break away. Filling it with stuff might also work for a short time, however in the summer, everything expands and contracts throughout the day, and it will do that at a different rate and speed than the glass.
I guess the bottom line is - try anything.
Ultimately you will need to replace it.
Ultimately you will need to replace it. Supreme Member
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
yea.. you can buy a third gen windshield for around 138$ my last check. all you have to do is pick it up. installing it is a 15 minute job.. and can say you a bunch of money over having it installed. especially if you have a lame installer like i did. 197$ for the windshield and install only to have my dash pad broken up by the guy when removing the windshield.. and then the company comes back saying it was already broken (because it is an old car and it is a common problem).. So in the end to replace the dashpad with a new one ( and there is one out there and i know which warehouse it is in) would cost me $300 more clams.... Cheaper to do it yourself...
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
[For multiple cracks against the stripping, you could probably get away with some tape for a short time.
The front windshield is basically laminate glass. 2 pieces of glass with a clear bond agent between the two sheets.
If it chips/breaks on the edge, the crack will continue to run it's course so long as there is a twisting force applied (the body flexing) to the glass. There is no real way to stop it if the crack starts from the edge.
To describe it simply, you're watching the pane glass that's on a house window break in ultra slow motion.
Car: 1987 Iroc-Z
Engine: 355
UGH! lol, i need to find a place around here that sells them that cheap.. $220 at the nearest place i checked for installed (claims they charge like $15-20 to install and everything else is just window price). I can live without right now tho.. just have a chip and its all swirl-scratched..
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
I got my windshield installed and bought for free... That's why I like State Farm! Windows are non-deductable. Check with your insurance company first!!!
Car: 1987 Iroc-Z
Engine: 355
Wisconsin Mutual... they are terrible.. but CHEAP... Let me put it this way.. i got rearened in my dads car about two years ago.. the police report said i wasnt at fault.. my dad's insurance goes up.. we didnt make a claim or anything... bastards
Originally posted by Angelis83LT
yea.. you can buy a third gen windshield for around 138$ my last check. all you have to do is pick it up. 197$ for the windshield and install only to have my dash pad broken up by the guy when removing the windshield..
I agree with the comments about insurance. Check there first. I would not play games with the windshield. It plays a very integral part in the car. A hack fix, even temporary, could become a dangerous situation.
Bohemian
Aug 15, 2017 05:11 PM
codeysabatini
Nov 10, 2015 04:07 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
