B&M Mega shifter for 4th gen console???
Old Jul 26, 2005 | 11:16 AM
Wind Charger's Avatar
Car: 1988 GTA TRANS AM, 1986 TRANS AM
Engine: L98, 5.7 TPI reborn, comp cam/heads maybe HSR this spring 5.0 TPI
Do they make such a thing?? I havent seemed to find any?
Old Jul 26, 2005 | 12:23 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Nope.
Old Jul 27, 2005 | 12:21 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Someone posted on here how to make it work correctly tho.. something about bolting it up a little differently... and you would have to use a manual shift plate.
Old Jul 27, 2005 | 11:11 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I mounted one into my car with the 4th gen manual console,
Old Jul 27, 2005 | 12:46 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
do you have any problems with the ratchet action? and what pwr window buttons are those from?
Old Jul 27, 2005 | 03:42 PM
Zepher's Avatar
It was ok, just have to do some trimming of the manual plate to keep the shifter from popping up the console plate.
those are stock 3rd gen switches mounted into a plate I made and set into the ashtray hole of the console.
Car is no longer an Auto, I converted to a manual last year.
Old Jul 27, 2005 | 05:43 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
How did you prevent the shifter from cracking the back of the console when dropping down to 1 ? I had that problem.. cracked my console... goku mad
Old Jul 27, 2005 | 06:59 PM
Zepher's Avatar
You have to angle the shifter with washers so that you get clearance at the front and at the back.
My problem was when going to 1st, the console would pop up at the front.
I also beat the **** out the of trans tunnel to get it nice and flat.
1992 Trans Am
May 10, 2023 07:19 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
colton_carlson
Mar 8, 2019 12:21 PM
Casey Meyers
Mar 2, 2016 10:46 AM
