Is this repairable?
Old Aug 28, 2005 | 04:09 PM
demetri's Avatar
Is this repairable?
http://img240.imageshack.us/img240/7710/dsc017123bd.jpg
Old Aug 28, 2005 | 04:16 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Probaly cheaper to buy a primered fender and having the paint fixed.
Old Aug 28, 2005 | 04:25 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
That could be fixed but alot easier and probably going to be cheaper to pick up a new fender.
Old Aug 28, 2005 | 04:44 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
some teal ducktape and a pice of angle iron will fix that right up
all kidding aside, yea it could be, but it would be cheaper to buy a new fender and repaint it.
Old Aug 28, 2005 | 04:55 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Yeah, fenders cost what... $75? Not worth having a body shop bang around on it and filling something that can be replaced for so cheap.
Old Aug 28, 2005 | 06:25 PM
demetri's Avatar
Its going to get painted. So either i buy a new panel or let them fix/paint the whole car, what would be cheaper
Old Aug 28, 2005 | 06:28 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
generally the less the body work when your getting a car repaintied the cheaper the paint job will be
Old Aug 28, 2005 | 06:30 PM
demetri's Avatar
yea but i want a OEM fender, GM still sells em right? how much would those cost?
Old Aug 28, 2005 | 06:42 PM
crrllmich's Avatar
Engine: L03, LS1
Well you want brand new or used? New there about 130 with primer on eBay. Used about 50$
Old Aug 28, 2005 | 07:16 PM
demetri's Avatar
I want new ones. who does everyone go with to paint? i used maaco before
btw i also have a little dent in the back rear right. the spoilers gone(only the little piece) and its dented a little bit.
Old Aug 28, 2005 | 07:34 PM
crrllmich's Avatar
Engine: L03, LS1
http://cgi.ebay.com/ebaymotors/91-92...QQcmdZViewItem
108$ there for a brand new one.
Old Aug 28, 2005 | 07:36 PM
demetri's Avatar
sorry thats aftermarket and for a z28
Old Aug 28, 2005 | 07:48 PM
kaseobeer2585's Avatar
uh, isnt your car a Z28?? and why does it matter if its an aftermarket fender or a GM fender its still new all the same.
Old Aug 28, 2005 | 07:50 PM
demetri's Avatar
No mines an RS and aftermarket parts are always different, ill probly order one from GM
Old Aug 28, 2005 | 08:16 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
i dont believe that the would be different, it wouldnt be economical for GM to use all different body peices on one model car for each of its sub models.
Old Aug 29, 2005 | 12:33 AM
crrllmich's Avatar
Engine: L03, LS1
Go to a junkyard then and pull one.
Old Aug 29, 2005 | 01:12 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I have a junkyard fender on either car and I dare anyone to tell me which one it is. they both fit like new fenders. they line up and look just fine. You could do the same altho Camaro fenders are a PITA to rmove IMHO. But theprice makes it worth it.
Old Aug 29, 2005 | 09:47 AM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
aftermarket parts are usually made out off thinner sheet metal and dont alwyas line up right
Old Aug 29, 2005 | 09:59 AM
Hexane's Avatar
Car: 87 Camaro
Engine: 2.8 MPFI V6
I got a 50/50 chance to tell ya which one is the junker fender.
Old Aug 29, 2005 | 02:15 PM
jack_sparrow's Avatar
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
Maybe maybe not, depends on if you can straighten that front piece.
brett
Old Aug 29, 2005 | 03:05 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
RS or Z28, they both use the same fender.
Anyway, a used fender is a very good option as long as you can find one that doesn't need body work of its own. I would take a used GM fender over a new aftermarket fender any day.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
