increase heater air velocity
Old Sep 21, 2005 | 11:03 PM
rsvert's Avatar
Car: 91rsvert
Engine: 305 tbi
Transmission: auto
Is there any way to increase the heater so the air blows out faster? Is there a filter to change?
Old Sep 21, 2005 | 11:13 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Higher voltage to the blower motor via a DC-DC converter, or higher powered motor if you can find one.
Old Sep 22, 2005 | 12:04 AM
rsvert's Avatar
Car: 91rsvert
Engine: 305 tbi
Transmission: auto
thanks for the info.Im new to this board and after reading other peoples posts it seems like a common problem solved with a more powerful moter.Does anybody know if there is a filter that should be changed?
Old Sep 22, 2005 | 01:27 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
I think the filter stuff would have been only found in the 4th gens.. as far as I know.. it is a late 90's thing is when they started ctually putting another filter into the cars for the internal air I believe.
Old Sep 22, 2005 | 04:13 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
my sisters 87 did not have one when i redid the heater core. there was a dust buildup on the core fins themselves if i remember correctly. but a little tip, if you do all the work to go in there and clean it, just swap it out. they are cheap and a PITA to get too,
Old Sep 22, 2005 | 04:45 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Just drive faster??
Diff.
Old Sep 22, 2005 | 07:12 AM
Car: 86 T/A
Engine: HSR 355
Originally posted by Difflock
Just drive faster??
Diff.
Now that just doesn't make any sense.
Old Sep 22, 2005 | 08:12 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I stuck a new motor in my 85 IROC and the flow far exceeded my expections. Try it. Shoot, some of those motors are 20 plus years old. Add twenty years to your life and you'll probably slow down a bit too
JamesC
Old Sep 22, 2005 | 08:18 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Just drive faster??
Diff.
As in the old 2-60 air conditioning?
Seriously, what more powerful motors (if any) will fit and work in our 3rd Gens? Anything from an S-10, Saturn, etc.?
Old Sep 24, 2005 | 01:17 PM
rsvert's Avatar
Car: 91rsvert
Engine: 305 tbi
Transmission: auto
It looks like the thing to do is put in a new motor and drive alot faster, and maybe hang my head out alittle.
Old Sep 25, 2005 | 01:43 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Just drive faster??
Diff.
Sure it does. There is definitely a forced air component to the speed of the air through the system, caused by the vehicles speed. To test this, move your control to "Vent", and the fan to the far left (off). As you drive, the air coming through the vents gets faster as you speed up.
Old Sep 25, 2005 | 09:43 PM
Red1991TransAm's Avatar
Car: 1991 Red Trans Am
Transmission: 5 spd manual
What he said!! Where do you get the more powerful motor? What kind? Or is it just more powerful b/c its new?
Old Sep 25, 2005 | 09:50 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
the 20 y/o stock motor is just a little tired, buy a new one and it will work like a newer car
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Blue419
Sep 10, 2015 01:03 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
