Lost lugnut key.
Old Oct 30, 2005 | 07:03 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
Lost lugnut key.
I lost my lug nut key. How do I get the lug nuts off? So I can keep my rims?
Old Oct 30, 2005 | 07:13 PM
Stevo's Avatar
Car: Pair of 92 Z28s
you have to drill into the side of the lug with an air hammer and try to get it to turn off, youll ruin the lug and have to get another set of locking lug nuts or just a regular lug nut. But ive heard you can sometimes get another key from a place but it depends what kind it is, if its stock or what.
Old Oct 30, 2005 | 07:20 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Do you have a socket set? If so, go and find the size that fits over the lug, then find the next size down and get a craftsman one from Sears. Hammer onto the lug, then unscrew it. It's as simple as that. I reused the same one all 4 times without problems, you don't have to hammer it on tooo hard. If not, craftsman has a lifetime warranty.
Old Oct 30, 2005 | 07:30 PM
Car: 89 GTA
Engine: L98 350
I tryed the socket idea and the people who put the rims on before me put them on way to tight and it just slips on the nugnut. maybe ill have more luck on the other 3 rims with that idea. and the drilling idea could that ruin the rim if i do it wrong?
Old Oct 30, 2005 | 07:33 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
You can get a tool at at autozone to get them off.
Old Oct 30, 2005 | 07:54 PM
Stevo's Avatar
Ive seen it done plenty of times myself i never personally have done it, but i dont see how it could ruin the rim...unless u miss the lug and hit the rim with the air hammer lol. Ive heard u could damage the stud...but i dunno it really doenst look that hard just never had to attempt it myself.
Old Oct 30, 2005 | 08:14 PM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
i took mine off with a socket.....maybe if you try one just a little bit smaller....mine socket fit very tight, i had to put it in a vice to pound th lug nut out of it after i got it off
Old Oct 30, 2005 | 10:14 PM
92RZ's Avatar
Car: 92 Camaro RS
I used an easy out. If you don't know what it is it's a drill bit type of looking thing that is reversed threaded so as you turn it, it tightens on the lug in the direction to loosen the nug. I had to torch the **** out of the lug to get it moving but it came off. I only did one, I'm to lazy to do the rest right now since the cars off the road.
Old Oct 30, 2005 | 10:16 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
Goto to a tire mounting chain. They usually always have a tool to get locking lugs off. You'll probally just have to prove to them that it is your car first.
Old Oct 30, 2005 | 10:20 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
go to any tire/wheel shop an theyll have the equipment
go to a discount tire if possible and theyll charge you 5 bucks to break the lock off
you are gonna have a hard time doing it yourself without the proper tools...itll take a tire tech about 2 mins to get it off without damaging your wheel
Old Oct 30, 2005 | 11:32 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
from personal experience, you could take an electric drill and simply sacrifice the stud its on by drilling out the center, then using a hammer and chisel to destroy the rest of the locking lugnut. I used this method to remove gta wheels from a junkyard car.. it was long and tedious but it did the job. Some of the previously mentioned strategies sound like they make more sense, though.
Old Oct 31, 2005 | 12:02 AM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
use what theifs around here use or used to use.... GATOR grip. it was that socket which was advertised on tv forever about 5 years ago. a socket and youlooked in where the nut goes and it was a bunch of metal rods about 1/16" thick each, so some of them would get pressed up to conform to the shape of the nut. well who says it has to be a nut, conforms to all kinds of shapes, including the pattern on ur tire key I'm sure , dunno if they sell it anymor ethough
oh here we go did a little search for ya
gator grip AS SEEN ON TV
another page with betteeer pictures
better pics click here
Old Oct 31, 2005 | 12:46 AM
Car: 89 GTA
Engine: L98 350
well i cant take the car anywhere its a parts car i want to rims off it. so i got to do it at home
Old Oct 31, 2005 | 08:00 AM
just2quickz28's Avatar
Car: 86 IROC
12 point socket and a large breaker bar and some Power Blaster always does the trick, seems like every car ive bought in the last 4 years no one bothers to give me the lug key
Old Oct 31, 2005 | 04:01 PM
Car: 85 TA
The gator grip sounds like a great idea as long as it will fit into the key lock nut pattern...it would be a lot easier thatn trying to pound the old lug nut out of a socket.
Old Oct 31, 2005 | 07:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you're going to do it this way, a cobalt drill bit is your best friend.
Old Oct 31, 2005 | 07:40 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I used to work at Sears Auto Center.. our "equipment" was a 12 point Craftsman socket, a 1/2" breaker bar, a vice, a punch and a hammer
If you have access to a welder, you can try and weld a nut on the lock.
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
Gunner242
Dec 25, 2015 04:49 PM
3.8TransAM
Sep 27, 2015 08:37 PM
