Replacement felt for L-brackets for windows....
Old Nov 3, 2005 | 08:12 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i wish i had a pic to show, but since i dont i will try to describe them....they are the brackets that mount to the top of your door (under the door panel) and they rub up against your windows to keep them moving on the right track
My problem is that mine have worn away all of the felt and are now rubbing lines into my tint
anyone know where i can get felt that will work for this type of job??
I tried getting an extra set, but they were in bad shape also....
Thanks!
Old Nov 3, 2005 | 09:14 PM
LT1guy's Avatar
Car: 1987 Trans Am
Find a glass shop that specializes in replacement glass for old cars; they'll have all types of felt. I use http://www.vintageglass.com
Old Nov 4, 2005 | 01:57 AM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Those are still available from GM and other distributors such as Classic Industries.
Old Nov 4, 2005 | 07:57 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well i tried GM and they wanted like $50 EACH!!!!
but i will have to try one of those other places.....thanks
LT1guy...thanks for the suggestion, but vintage glass said that they didn't carry it....
Old Nov 4, 2005 | 08:13 AM
KintaroOe's Avatar
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
i think the fiero felts are the same size and if they are you can try a website www.fierostore.com for new ones that are real cheap.
Old Nov 4, 2005 | 08:31 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
thanks!!!
that is A LOT cheaper than what GM wanted...lol and it even says on it GM restoration part.....
do you know for sure whether or not they are the same size?? it does look similar.....
Old Nov 4, 2005 | 10:11 AM
pondriver's Avatar
Engine: 350 HSR
Wow. I bought mine from classic industries and paid 8.95 each for them. I just checked my catalog and 82-87 model price is 48.95 each. Model years 88-92 are 8.95 each. Glad I've got a 92.
My old ones may not be too bad shape. I'll look and see if they are still good. I'll let you have them cheap if your interested.
Old Nov 4, 2005 | 12:59 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
i wonder what the difference is in the two types which causes such a dramatic price difference???
Old Nov 4, 2005 | 03:07 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
88-92 were improved to better hold the window. If you look at the picture on this thread there is a large rectangle hole behind the felt. There were two hooks bolted to the window that went into the hole when the window was up. This gave the window a much more solid feel and less likely to rattle.
The black plastic trim piece on top of the door panel was also notched out for clearance for the hooks.
The later style felts should work fine on early cars. You may have to take a dremel or file to the black plastic trim piece to make clearance for the ears on the sides which aren't on the earlier style.
GM typically raises replacement part prices when they are getting low on stock and they are no longer producing the part or there isn't much demand anymore.
Old Nov 4, 2005 | 09:32 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
alright...thanks...i went to the local GM parts place and they could get one but it would take a week and he said that all sales are final.....so i wanted to make sure one would work before i went though with it
thanks!
customblackbird
Aug 15, 2021 10:16 PM
Fronzizzle
Mar 18, 2019 08:29 PM
redmaroz
Aug 16, 2015 11:40 PM
BurlyChev
Aug 16, 2015 09:08 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
