Hatch Light Question
Old Dec 11, 2005 | 09:08 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
When I bought my car it was in bad shape, and it had no light for the hatch. I found a light fixture and bulb but I'm not sure how to safety wire it up. It has a white wire and an orange wire. I'm also replacing the hatch motor assembly. So maybe I could wire it up then. Will the light come one only when the hatch is open? What about when the doors are open or the interior light is turned manually?
I have one more question also. Where is a safe place to ground an amp in the rear of the car? I only have about 3-4 feet of wire. The amp will be placed on the "hump" somewhere. Thanks-
Old Dec 11, 2005 | 12:31 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I know that the 1988 and earlier hatch lights have a manual switch to turn them on/off. My 1990 is turned on/off by the hatch pull-down unit. I don't have a Camaro or Firebird Service Manual for 1989 (aka HELMS manual). I'll describe how to wire it for the pull-down motor to power it. There is a red with white stripe wire that is +12v. It connects to one side of the hatch lamp. The other side connects to a black with orange stripe wire from the hatch pull-down motor.
You SHOULD buy a 1989 Camaro Service Manual either from your dealer or online at www.helminc.com.
Lon
Old Dec 11, 2005 | 12:32 PM
lonsal's Avatar
double post.
Old Dec 12, 2005 | 05:00 PM
techno101's Avatar
Car: 1989 Camaro RS
thanks alot. I'll try and get it all wired up this weekend end. Anyone know of a safe ground spot for an amplifier in the " trunk"?
Old Dec 12, 2005 | 05:41 PM
lonsal's Avatar
I forgot to add that the black with orange stripe wire connects to a white wire with a small black connector on it coming from the pull-down motor wiring.
Lon
Old Dec 12, 2005 | 06:11 PM
I-rocin's Avatar
Car: 87 iroc-z28
Engine: vortec tpi 350
Transmission: built 700r4
please, for safety's sake, use good connectors, and make sure they're tight
i don't wanna see a burned down 3rd gen ebcause of a bad connection
Old Dec 12, 2005 | 06:16 PM
techno101's Avatar
Car: 1989 Camaro RS
Oh I will make sure everything is good and secure. I'm just not sure where I can ground my amp to. As you can see I'm no electrician.
Old Dec 12, 2005 | 07:45 PM
I-rocin's Avatar
Car: 87 iroc-z28
right underneath the hatch motor, there are a couple of brackets, drill through one of those, and put a bolt and nut on it, make sure its tight
any metal part of the body will work as a ground
Old Dec 12, 2005 | 08:30 PM
lonsal's Avatar
I think it is really thoughtful of you to make it easier for a thief to pop the hatch and see the nice amplifier he's stealing. It will save him the trouble of having to bring his own flashlight.
Lon
Old Dec 13, 2005 | 04:59 AM
techno101's Avatar
Car: 1989 Camaro RS
Could i ground my amp to the back seat belt bracket, the one that is under the trim piece that the shoudler strap comes out of? I wanted to thank you guys for the help, I will post a few pics of my new interior. Hopefully sometime his week, Thanks again-
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
