Duplicolor Rust-Fix??
Old Jan 24, 2006 | 11:05 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Anyone have any experience with this stuff? Duplicolor Rust-Fix??
Here is what it says on their website:
"Rust Fix® rust treatment destroys rust on contact. It sprays on clear and turns to a black metal-protecting coating to fight future rust from forming. Specially formulated to be used with body filler and fiberglass. Sandable for a smooth, even finish.
- Stops rust on contact
- Sprays on clear
- Works on body filler and fiberglass
- Sandable for smooth even finish
- Ideal for rocker panels, paint blisters and all metal surfaces. "
Old Jan 24, 2006 | 11:15 AM
subliminal's Avatar
Ive used it before on my rear end, it seems to work. Though I dont know for how long.
Old Jan 24, 2006 | 12:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
it's like phosphoric acid in a can. I tried it, didn't work whatsoever.
Old Jan 25, 2006 | 12:45 PM
Steve51186's Avatar
Car: 1984 Trans-Am
Transmission: auto
Ive used Rustolium heavyly rusted metal primer, which seems to be pretty much the same. Ive only used it on areas with light surface rust. But after ive sanded it down. I havnt had a problem with that rust coming back in my cars yet (year and half-ish) and i live in RI.
Old Jan 25, 2006 | 12:58 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Thanks for the feedback. Everything I have read on other forums has been very positive about this stuff. I am going to give it a try this summer.
Old Jan 25, 2006 | 01:40 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm doing my rear end with it as well. Wire brush, wash and towel dry, then spray and you should be fine.
Old Jan 25, 2006 | 03:16 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Why not POR-15?
JamesC
Old Jan 25, 2006 | 03:18 PM
Car: 86 T/A
Engine: HSR 355
Does POR15 come in a spray can?
Old Jan 25, 2006 | 03:21 PM
JamesC's Avatar
Not that I know of. However, it can be sprayed.
JamesC
Old Jan 25, 2006 | 03:30 PM
Car: 86 T/A
Engine: HSR 355
Not really convenient for me. I'll stick with cheap rattle can stuff for the axle.
Old Jan 25, 2006 | 03:36 PM
JamesC's Avatar
I've done the a-arms and the entire rear end with POR-15 (as well as some portions of the body), but those pieces were out of the car, which, of course, made them much easier to deal with. Still, good stuff. Done right, you'll never have to redo.
JamesC
CommieTerrorist
Dec 10, 2010 11:35 AM
70gmc
Jul 16, 2007 08:12 PM
crazy3rdgen
Sep 15, 2004 05:17 PM
CamaroZ_85
Apr 21, 2001 03:19 PM
