Need pics of battery trays
Old Feb 19, 2006 | 03:13 PM
Quick-IROCZ's Avatar
Car: 1987 IROC-Z28
Engine: 305 Tpi
Just this week, I carefully removed the old factory installed battery tray, spot welds and all, I used metal wedges and hammers to bang the pieces open, bent them off with vice grips, some parts I had to cut around because of the welds. From here it was my dad's idea to use an angle grinder to grind down what was left of the spot welds. After I get the frame around what used to be the tray to 'bare metal', I'm installing a battery tray I bought from Camarosandclassics.com for $50.
The problem is I don't know how It should fit properly, It definitely doesn't fit like factory right now. Can anyone pull you battery out and take a picture? Or are there diagrams somewhere how to do this? Thanks
-Quick
Old Feb 19, 2006 | 08:46 PM
trigger GTA's Avatar
Car: 92 TA vert
try this
http://www.ccfbg.com/projectcar/DSC01834.JPG
http://www.ccfbg.com/projectcar/DSC02028.JPG
http://www.ccfbg.com/projectcar/DSC02029.JPG
http://www.ccfbg.com/projectcar/DSC02041.JPG
http://www.ccfbg.com/projectcar/DSC02784.JPG
Old Feb 19, 2006 | 10:04 PM
Car: 1987 IROC-Z28
Engine: 305 Tpi
I see that, if you're standing next to the fender, the top left corner, most of that 'triangle' was cut out, mine looks like this
http://files.automotiveforums.com/ga...58681tray2.jpg
think anyone can spot what's wrong with it? Is it the alignment? I also had to remove some of the actual frame, as you'll see, on the right side.
Old Feb 20, 2006 | 04:22 PM
Car: 1987 IROC-Z28
Engine: 305 Tpi
Also, does anyone have pics from underneath the tray, so I can see how it connect to the frame?
Old Feb 20, 2006 | 05:01 PM
Car: 92 TA vert
this pic shows the hole tray out of the car.
there should be no weld on the underside. you should be able to do it all from the top
Old Feb 20, 2006 | 05:09 PM
Car: 1987 IROC-Z28
Engine: 305 Tpi
No, I mean I have a problem and need to see the bottom, I bent the frame by the triangle out of shape and wanted to see how it looks normally
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Lanz06
Mar 13, 2019 06:07 PM
64goatman
Sep 9, 2015 01:09 PM
Formula_88AE
Sep 3, 2015 01:47 PM
andy74
Sep 3, 2015 08:41 AM
