door handel
Old Mar 1, 2006 | 04:21 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
door handel
can you help what is an easy way to get to the door handel bolts so i can remove it????
Old Mar 1, 2006 | 04:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No easy way. You'll have to remove the door panels.
JamesC
Old Mar 1, 2006 | 05:43 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
i know but the glass is in the way
Old Mar 1, 2006 | 06:09 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
uhh, roll the window up!
Old Mar 1, 2006 | 10:23 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
still in the way ***
Old Mar 1, 2006 | 10:24 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Ummmmmm roll down the window
Old Mar 1, 2006 | 10:28 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Dude how can the window possibly be in the way if it is rolled all the way up Remove the door panel, and stick your arms in the big holes and remove it, not cool calling people an *** for trying to help, do a search on your own if you are going to be so abusive.
Old Mar 1, 2006 | 10:31 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
dude i am not a retard i tried it all the window all the way up and down you can only get to 1 of the bolts the window blocks the other
Old Mar 1, 2006 | 10:38 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Well either buy the right tools because I have done it many times or remove the entire window if are so inclined to do so
Old Mar 2, 2006 | 12:20 AM
CYARS92's Avatar
He can't get a door handle off & you want him to try removing the window?!lol
Seriously, All you need is a long wrench and you should be able to reach it. The glass should be a good 2" away from it.
Old Mar 2, 2006 | 09:44 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Put down the ratchet and pick up a wrench. Go back to the door and try again.
Old Mar 2, 2006 | 11:07 AM
robbyho21's Avatar
Car: 88 camaro
Engine: 355
Transmission: rebuilt 700-R4
yes exactly!! do you own a wrench, i just painted my car and put the handles back on took me 2 mins to do both sides
Old Mar 2, 2006 | 02:27 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
The first thing i did to my car was a door swap and handle swap and as they said it is VERY easy to do.
Old Mar 2, 2006 | 02:35 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Easiest to just drill a hole thru the glass. That way the socket and extension will fit.
Old Mar 2, 2006 | 02:57 PM
Jim85IROC's Avatar
Old Mar 2, 2006 | 03:39 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
**** off
Old Mar 2, 2006 | 05:01 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I've done this quite a few times myself, and if you can't figure it out, then you should really have someone else do it.
Old Mar 2, 2006 | 05:05 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
wow. everybody needs to chill out.
so maybe he didn't think of using a wrench at first. telling him to use wrench is all he needs not a bunch of trach talking.
good luck getting the handle off I'm sure you'll find it easy once you go at it with a wrench.
Old Mar 2, 2006 | 06:09 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
ya it is off i just did not have a wrench long eanuf to reach it and u cant get your hand in there but thanks for all of u who were an *** we are supposed to help each other out not talk ****..
thank u darkhorse
Old Mar 2, 2006 | 06:17 PM
CYARS92's Avatar
so maybe he didn't think of using a wrench at first. telling him to use wrench is all he needs not a bunch of name calling.
If you look, I believe he started the name calling.
Glad you got it off.
Old Mar 2, 2006 | 06:22 PM
Engine: L98 and L03
post above changed
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
