Will a GTA hood fit a Camaro?
Old Mar 21, 2006 | 12:46 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
Old Mar 21, 2006 | 12:56 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
sure, if you put a firebird front clip/headlights and fenders on it
Old Mar 21, 2006 | 01:09 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Take a good look at the front end of both and see what the key difference is.
Old Mar 21, 2006 | 01:27 PM
JTZ28's Avatar
just a wee bit of difference between the two of them
Old Mar 21, 2006 | 01:37 PM
Stevo's Avatar
Car: Pair of 92 Z28s
was a good laugh though
Old Mar 21, 2006 | 04:45 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I'm going to say it will fit. But the fenders and headlights are gonna give you some trouble.
Old Mar 21, 2006 | 08:50 PM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
might be cool if you welded in something to compensate for the headlights.
Old Mar 21, 2006 | 09:22 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
No. It will not fit. Period.
Old Mar 22, 2006 | 02:34 AM
purpleZ-28's Avatar
just get out a torch and a welder. itd be different.
Old Mar 22, 2006 | 04:22 AM
miamivice's Avatar
Car: 88 GTA
and maybe make a tech article on how thats done. have you ever seen a camaro and a firebird...the lines are totally diffrent. a birdy front end slopes down more than a maro. would probably be easier to just start w/ a flat piece of sheet metal and then get the torch adn the welder out and start bending it up
Old Mar 22, 2006 | 09:02 AM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
no it will not fit with out moding the car. BUT i have thought a camaro would look real cool with a power bulge hood on it.
Old Mar 22, 2006 | 09:34 PM
purpleZ-28's Avatar
well, if you took a flat camaro hood, and the trans am hood, you could cut them both up and weld the parts off the TA you want to keep onto the camaro hood. obviously theres more work involved than that, but it can be done. if something doesnt fit, make it fit. anything can be done
Old Mar 22, 2006 | 09:35 PM
purpleZ-28's Avatar
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
3rdgenparts
Aug 6, 2015 09:03 AM
