Can i strip my bumper
Old Apr 12, 2006 | 08:31 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
I am in the process of painting my car and the paint on my front bumper is really chipped and cracking. I was wondering if their is a way to strip the paint off besides sanding if off and if anyone has done it. I was thinking of using paint striper or airplane striper but will that harm the bumper.
Old Apr 12, 2006 | 08:57 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Use any method that won't hurt poly urethane, sanding and stripping both will work just make sure you prime it with a plastic primer.
Old Apr 12, 2006 | 09:00 PM
jay92,85,79's Avatar
Car: 85z28,
plastic primer??? Whats this
Old Apr 12, 2006 | 09:04 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Not sure about the plastic primer, but they sell regular aircraft stripper and some lighter stuff designed for fiberglass. I know the fiberglass safe stuff wont hurt the poly., but the regular shouldnt hurt it either. Just check the back of the container to be certain. That aircraft stripper rocks, so i would definitely use that.
Old Apr 12, 2006 | 09:24 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
if you leave the aircraft stripper on the poly to long it will start to melt it... you would want to ues the fiberglass stuff.. should be a bit safer
Old Apr 12, 2006 | 09:44 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Plastic primer means it has flex compound in it letting it flex rather that just crack. I have used the aircraft stripper before its just shy of sulfuric acid in my book. Ill give the stuff that is safe for fiberglass a shot, i have an old bumper, ill try it on their first. Also can you get the fiberglass safe stuff from autozone or do you have to get it from a paint store.
Old Apr 12, 2006 | 10:09 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I mean before you paint the bumper it's a special primer thas does indeed flex and should be used before paint.
Old Apr 12, 2006 | 10:34 PM
Car: 85z28,
Well u could just use reg primmer and add a flex agent to it.. U might want to check with your paint suppiler. Some of the paints u do not need to add flex to the primer.or clear
I allways send my bumpers out to keystone. They media blast them and them prime them with a water born primmer. For 70 bucks a bumper. All i have to do is scuff it and paint it. How I look at it comes out way better and cheaper.
Old Apr 12, 2006 | 11:18 PM
Car: '87 Trans-Am
NAPA sells it Im pretty sure...
mcfastestZ28
Oct 5, 2015 07:12 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
