Help! Door lock problem
Old May 5, 2006 | 02:45 PM
88drop's Avatar
Car: 88 Camaro Convertible
Engine: anemic but fuel effecient 305 Tbi
Can't turn either doorlock on outside w/key (trunk lock works fine). Any advice?
Old May 5, 2006 | 04:36 PM
2slowRS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 liter(its slow)
this should probably be in a different section
Old May 5, 2006 | 04:42 PM
robmonte's Avatar
Car: 84 Z-28 HO
wd-40 use the red straw it comes with
and yeah you could try a different section
Old May 6, 2006 | 03:49 PM
88drop's Avatar
door lock problem-excuse post
This was the only post I could find-where should I be going? Thanks all & have a great weekend.
Old May 6, 2006 | 04:53 PM
tagta189's Avatar
This seems like the only place I can see for a question like this,give the guy a break huh?Anyway to answer the question,like they say use some wd40 on the lock and latch assys inside the door.Do the manual lock levers inside work or do they feel stiff?I am assuming it is the right key for the locks.You might have to take the inside door panel off and reach in there and work the lock levers by hand after spraying the heck out of the mechanisms.That freed mine up after they rusted and froze up.If that works make sure and get some oil in there afterwords to keep it from happening again.Good luck...
Old May 6, 2006 | 10:46 PM
robmonte's Avatar
Car: 84 Z-28 HO
oil after wd-40, wd-40 cleans and oils lubes
Old May 7, 2006 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
It's quite possible that, through lack of use and maintenance, the locks are frozen. If so, you'll need to replace.
A shot of Lock-Ease from time to time will do wonders.
JamesC
Old May 9, 2006 | 02:25 PM
88drop's Avatar
door lock problem
Thanks all-I was hoping to avoid having to remove door panel but after trying the wd or lock-ease, I'll see what happens. I assume the key is correct but from a guy ( he neglected 2 tell me of problem until after I purchased it)so can't verify but it opens the hatch & it's mate turns ignition fine.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
neekolzun
Aug 24, 2015 04:59 PM
g.l.mos
Aug 22, 2015 12:02 AM
