Loose door handles
Old Jun 12, 2006 | 09:33 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Loose door handles
my door handles on my 84' r so loose it seems there goin to fall off, will they fall of or can i tighten them?
Old Jun 12, 2006 | 11:12 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
I think they got it the first 2 times
Old Jun 12, 2006 | 11:17 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
be sure they are tight bolted to the door first and then to tigten up the slack just push the rod thats attached to the handle on the inside a bit more stright. it has a slight bend but if ya strighten it a tad it will help lessen the rattle OR you can go on e bay and buy a new set for $10 each.
Old Jun 13, 2006 | 06:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Often a small spring in the handle itself breaks and allows flop. No amount of tightening handle to body will help. Replacement is the only solution for this problem.
JamesC
Old Jun 13, 2006 | 09:31 AM
Car: 84' Trans Am
JamesC
I think that happened to mine, could i just leave it like that or will it fall off?
Old Jun 13, 2006 | 08:01 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
naaa, wont fall off but it sure makes for a sloppy handle. go to a good parts store and in the HELP! section they sell door handles as well for a lil better than $10 IIRC.
Old Jun 13, 2006 | 08:08 PM
Car: 84' Trans Am
r they hard to replace?
Car: 84' Trans Am
Car: 84' Trans Am
Car: 84' Trans Am
Old Jun 13, 2006 | 08:09 PM
Car: 84' Trans Am
Old Jun 13, 2006 | 08:19 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
one question at a time!!!!!!!!!!!!! lol. naa not hard to replace. pull your door panel off, then use a 10 mm wrench and un do the 2 nuts holding it on. there will be a rod with an S or Z shape sorta that hold the rod on. ther will also be a clip, just pop the clip and snake the rod out and its off.
Old Jun 13, 2006 | 08:21 PM
Car: 84' Trans Am
k, thanx 4 the help, my computer kept locking up when i hit the submit button, dang computer.
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
you gotta stop dong that there not stupid, LOL, JK
I hate when that happens or when im on this site and I type somthing wrong and i go to hit the edit botton it kicks me off the internet that makes me VERY mad
Last edited by 83camaroMN; Jun 13, 2006 at 08:23 PM. Reason: Automerged Doublepost
Old Jun 14, 2006 | 05:22 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
man, $10? i just got quoted at $25 each!
so where are you shopping at?
Old Jun 14, 2006 | 06:13 AM
JamesC's Avatar
Should you decide to dig into the door, check the sticky at the top concerning "window/door rattles".
JamesC
Old Jun 14, 2006 | 11:26 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
a loose door handle shouldn't fall off, but it will eventually break. replacing them is cheap and easy. those HELP! door handles were way too expensive at the local advance auto. i got a pair on ebay for less than advance is charging for 1. it's a very easy swap, well worth the time and money.
Old Jun 14, 2006 | 11:42 AM
Car: 84' Trans Am
JamesC
k, thanx ill look into it.
Is there anyway from preventing them 4 they dont break?
Last edited by 84'Firebird; Jun 14, 2006 at 11:43 AM. Reason: Automerged Doublepost
Old Jun 14, 2006 | 09:47 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i guess i mis read the price or they went up. its been a lil while since i looked. yea, evilbay has them all over the place for $10.
Old Jun 16, 2006 | 06:52 PM
purpleZ-28's Avatar
the cheapest ive seen em go for is $25 a pair on ebay, plus like, $10 shipping.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Buggy Disaster
Sep 17, 2015 05:12 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
NiG
Sep 7, 2015 11:25 PM
