Outer Door Window Weather Sweep Seal?
Old Sep 30, 2006 | 03:42 AM
Burntz's Avatar
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
I was looking through Modern Day Muscle and was like WOW they have all sorts of crazy oddball parts, but their seal for the outer window is $65. Is that worth it at all? I REALLY need a pair, and was going to go by sum yards to see if i could find any decent ones..
Anyone dealt with MDM? are they honest and do they have good products?
Old Sep 30, 2006 | 03:59 AM
Burntz's Avatar
Car: 1986 Trans Am
Axle/Gears: 9 bolt
Or Should I go with Hawks?
Camaro/Firebird 82-92 New GM Outer Door Window Felt Strip L - $39.
Anyone have any experience with either of these? Are they the originals and will they bolt up? Are they quality?
Old Oct 1, 2006 | 12:49 AM
Burntz's Avatar
Car: 1986 Trans Am
Axle/Gears: 9 bolt
cmon anyone? i dont want to order them if they'll be ****, someones got to have sum info on Modern Day Muscle
Old Oct 1, 2006 | 06:01 AM
LarsZ28's Avatar
Personally, I'd go with the GM ones. I have no experience with the other type, but you cant go wrong with the GM original ones..
Old Oct 1, 2006 | 06:55 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
I bought mine from GM. They are still available.
Old Oct 1, 2006 | 07:14 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Check eBay for them...I bought mine off of there from 1A Auto. Parts were of good quality. I wrote about them and the install process in the Parts Review section of this website. Cheaper than GM, too.
Old Oct 1, 2006 | 10:43 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
I just bought a pair from gmpartsdirect . com. They were 65 shipped to me. I think they are 24$ each plus the "shipping" costs. Made my freshly painted car look much newer, without brittle 14 yr old ones on there.
Old Oct 2, 2006 | 10:29 AM
Burntz's Avatar
Car: 1986 Trans Am
Axle/Gears: 9 bolt
how much were they?
Old Oct 2, 2006 | 08:46 PM
Bull's Avatar
Engine: LT1; None
Can't recall off the top of my head. I can check, but just search for seller 1A Auto on Ebay and look in their online store.
Old Oct 6, 2006 | 02:52 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
I paid $39/each plus $10 shipping for authentic GM seals from Hawks Thirg Generation:
4264-WS, Camaro/Firebird 82-92 new GM outer window felt strip, right
4265-WS, Camaro/Firebird 82-92 new GM outer window felt strip, left
They bolted right up, fit perfectly, seal perfectly against the glass & inner strip and look great on my '88 IROC-Z.
Old Oct 8, 2006 | 06:54 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Got mine at the GM dealer the other day for my 89....Man do the make a big difference.....paid 29 each side...It was worth it, did not have to wait just went and got them.....They are a small pain to change tho.....Maybe only 20 per side cant remember now...Tom
Old Oct 8, 2006 | 07:47 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Anybody got a pn on them through gmparts direct?
Old Oct 8, 2006 | 07:49 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
will try to get you the part number tomorrow when i go to work..I got lucky, and my dealer had them here (Houston Area) he made me a deal cuz they was old and all, been on the shelf fo awhile..Tom
Old Oct 8, 2006 | 09:25 PM
Yep bolt up is the literal deal.
Once the inner door trim was removed, the window lowered, the triangle guide loosened and the front top weather strip pealed back, about half of the small bolts could be accessed with a 1/4" socket, the other half required use of an open-end wrench.
Also it was necessary to move the two felt anti-rattle pads that press against the window on top of the inner door.
Old Oct 9, 2006 | 06:21 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Yes, thats what ya do...Man tho it is a pain, at least it was for me...PLUS sometimes you have to slighty modify the holes in the new ones, each door is just a little different, no big deal really, but I like to complain....LOL....It looks SO sweet when they are done......Mine looked so bad to begin with all broken, and cracked...Sure does compliment new paint....
Old Oct 9, 2006 | 07:50 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
modern day muscle is a good place to deal with
you should call first and make sure that you are getting NOS strips
Old Oct 9, 2006 | 09:07 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Also got mine from Hawks, actual GM parts. Install was as described above. Not a big job but tedious. Gives a nice finished look to the car compared to the busted up seals that I had. Seems like a lot of money for this crap though.
Old Oct 9, 2006 | 04:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Check sig...
And I have bought the JCWhitney w/seal before.
It contributed itself as a little extra fill at the dump.
Old Oct 9, 2006 | 06:42 PM
Well if you spread the referb cost across the life of the seals it isn't bad at all and really makes a diff in appearance.
Now, even with the windows down the outer & inner seals touch for a nice sealed look, sweet.
Gees, I even just replaced my old ratty hood liner and now I'm proud to open the hood it looks so nice...
Old Oct 17, 2006 | 08:46 PM
Red90IROC's Avatar
Car: 1991 Trans Am
Engine: 5L TPI
I'm interested in the part numbers too in case anyone has them... TIA
Old Oct 18, 2006 | 07:09 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
You will be glad you did it.......Couldnt find the number tho, but I just went to the GM dealer, and ask for the part, they looked it up...Lots of times they will knock off on the price if you ask...It is just in their way, cuz it is old...Tom
1992 Trans Am
May 10, 2023 07:19 PM
billybob6110
Sep 23, 2015 01:30 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
