T-top Anger
Old Oct 17, 2006 | 08:53 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
T-top Anger
It was raining hard here today, and my wife told me when she got home that the t-tops are leaking once again! I spent hours replacing the seels this summer...getting the channels spotlessly clean, applying a nice bead of Permatex black RTV around the sealing area. I also adjusted the tops so that they fit pretty tightly, as far as I can tell. They are actually a bit hard to latch into place because of the way I adjusted them so they are tighter. This sucks, and makes me appreciate hardtop cars even more.
I guess my option now is to apply some more RTV all the way around the edges and hope for the best.
Old Oct 17, 2006 | 10:53 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Sorry to hear that. I've been working on my seals in between school and work for weeks now. I just finished refurbishing my weatherstrip retainers and attaching them. The car is ready for for the weatherstrip and I'm afraid i'll have leaks when its all said and done.
Old Oct 17, 2006 | 10:57 PM
Bull's Avatar
Engine: LT1; None
Yeah, I was sorry to hear it when my wife told me, too!
Clean channels, new seals, RTV...still leaks. I guess the only thing I can do is maybe try to adjust them differently and use some more RTV. Sucks though. I hope you have success the first time around!
Old Oct 17, 2006 | 11:04 PM
Frank89IROC's Avatar
Wow that's really a drag, fortunately for me, when I replaced all the weatherstripping, it cured the one leak that it did have. Can you pin point exactly where it's leaking from? Hopefully it's at only one spot. Remember the weatherstripping that goes on the t-top itself can be adjusted forward & back.
Old Oct 17, 2006 | 11:06 PM
Bull's Avatar
Engine: LT1; None
I'll try to do some investigative work as to where the leak is...wife tends to drive the car. How do you adjust the rubber on the t-top itself?
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
i found what helps is if you get some foam strips, it's kinda like weatherstripping but one side has adhesive on it you can buy rolls of it in varying thicknesses and widths, but i put it along the existing t-top weatherstripping and it seals tightly around the perimeter of the top and keeps the water out. i'll try to get some pics and show you what i mean.
Old Oct 17, 2006 | 11:14 PM
If you glued the piece that goes on the t-top, you won't be able to do it. I found that it's not necessary to put glue on the weatherstripping that goes on the t-top. It just slids on and is held by the lip on each side very tightly. You have to ensure that it is centered exactly right or you'll have a small gap in the front or rear where it meets the weatherstripping that is on the car.
Old Oct 18, 2006 | 09:44 AM
camaro88sc's Avatar
Car: 1988 Chevy Camaro SC
Engine: 305 TBI
i know the feeling of leaky t-tops. Mine have leaked now for like 2 years, i have taken them off reput them on and still leaky even worse then ever. I even tried sealing the whole t-top down once and that didnt help at all. good luck i hope u r able to solve your problem, i think the only way i will be able to fix mine is when i redue the whole car once i have some money
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
