How do I remove the door guard glue/tape crap?
Old Oct 21, 2006 | 10:46 AM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Engine: 305 V8 carb'd
How do I remove the tape or glue crap that holds those door guards on. I've been trying to scrape it off all morning, but it's just not comming off . Everything else falls apart when you don't want it too, but when you want something to come off it won't budge. I'm about to grind the sh*t off . So what is the best way to take it off. Please help
Old Oct 21, 2006 | 11:20 AM
MavViper's Avatar
You're talking about the door moldings, right? Most of mine came off pretty easy, but I sprayed all types of cleaners and stuff on it and the rest wouldn't come off. I let my body shop deal with it, I imagine they will sand it off
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
are you talking about the side molding glue stuff? use goo gone or something like that...i ended up just sanding mine off with a DA b/c i got lazy
Old Oct 21, 2006 | 11:48 AM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Yea it's from the side moldings. I've used every type of cleaner & chemical I own. I don't have any goo gone. I think I may just sand it off then. This stuff is pi**ing me off! I can't belive this actually holds that good.
Old Oct 21, 2006 | 12:11 PM
gray89vert's Avatar
Engine: 305 TBI LO3
you COULD get most of it off with a razor blade i would imagine. sanding it is easy enough
Old Oct 21, 2006 | 12:37 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
I tried the razor blade at first & stupid me cut into the paint. So I just put that down. I am sanding right now & it's working.
Old Oct 21, 2006 | 02:12 PM
gray89vert's Avatar
Engine: 305 TBI LO3
are you getting your car painted?
Old Oct 21, 2006 | 02:20 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
eventually
Old Oct 21, 2006 | 02:36 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Try warming it up with a hair dryer, should make it wasyier to peel off.
Old Oct 21, 2006 | 02:48 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
I tried that too, it didn't help much. I have sanded it off one of the doors & still have the other one to do. I am going to go to Walmart tomorrow & get some of that goo gone stuff & see if that will do it.
Old Oct 21, 2006 | 05:54 PM
gray89vert's Avatar
Engine: 305 TBI LO3
good luck
Old Oct 21, 2006 | 06:10 PM
NomadTA's Avatar
Car: 11 F350 CC DRW Dsl
I've used WD40 in the past to remove adhesive material. It takes off the stuff that holds on motorcycle tank emblems anyway.
Old Oct 21, 2006 | 06:47 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Originally Posted by gray89vert
good luck
I have some, I'll try that first then. Never thought to use that.
Old Oct 21, 2006 | 07:42 PM
gray89vert's Avatar
Engine: 305 TBI LO3
hmm never thought of wd-40. i should try that too
Old Oct 21, 2006 | 09:15 PM
rof51's Avatar
Best way to remove mouldings, badges, etc. fixed with tuo sided tape is to use dental flush string(cord) in a doubled or tripled fashion & long enough to wrap in your hands 7 in up & down motion pass it in betwen the moulding adhesive & metal. Thats how i ve done it. good luck
Old Oct 21, 2006 | 11:59 PM
vindoo's Avatar
Car: 89 Formula 350
I like that floss idea...Going to have to give that a try sometime...Mine was paint to get off too and they took some paint off with them.
I ended up sanding most of it off, painting the car anyway...
Vintageracer
Jan 10, 2020 05:33 PM
anesthes
Aug 26, 2015 01:37 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
