Help! hatch stuck shut!
Old Nov 2, 2006 | 10:31 AM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
I screwed up ! On my 86 Z28 I was replacing my pull down motor and bolted it up. It turned out to be the wrong one. The replacement was from a 92 RS.
The wire harnesses didn't match up. Well I shut the lid and the lock cylinder is not hooked up yet so the key wil not release it. Now I have the hatch stuck shut and yes the rear plastic is in place so I can't get to the motor from the inside without breaking it. Any ideas on how to get it open?
Thanks in advance,
Ray
Old Nov 2, 2006 | 10:53 AM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
It'd be easier if I had my car in front of me to look at, but I believe that if you remove the little light on that black plastic hatch panel, the one right on front of the motor, you will be able to access the motor and activate the manual release with a screwdriver.
I might be remembering incorrectly, but go and take a look.
Old Nov 2, 2006 | 11:06 AM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
Thanks Bull,
But this one has no lite. My replacement one does though. It sounds like I'll have to break it or cut a lite hole myself .
Thanks,
Ray
Old Nov 2, 2006 | 11:16 AM
84 trans am's Avatar
Car: 89 RS
Engine: 2.8
Transmission: t5
Would hotwiring the electric release work?(If you have it) Should if you just hook it up to a 12 volt source.
Old Nov 2, 2006 | 11:20 AM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
might I dont know ? good answer I ll try if you tell me how! if you could post directions. i'll try later. gott go to work now.
Thanks,
Ray
But I still have to get to the motor and then I may as well hit the manual release, If I can figure that out!
Old Nov 2, 2006 | 03:11 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
man thats sucks stupid hatch pulldowns find any good cars in the junkyards lately?
Old Nov 2, 2006 | 06:36 PM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
I completely bypassed the electric motor and made mine a good ol' manual open and closed by adjusting the height of the motor assembly, and tacked it into place.
Old Nov 2, 2006 | 08:30 PM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
Good idea , When I get it open!
Thanks!
Ray
Old Nov 2, 2006 | 09:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
This is why Im glad i stuck to my original(84) manual hatch release & why id never go with shave door handles.Anyway though if that small light in the rear compartment mentioned before was there.Youd be able to access the slot to insert a flatblade screwdriver.If you want that light anyway you may have to "guess" where the hole goes then release the latch afterwards.
Old Nov 5, 2006 | 02:34 PM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
HEY! I got it! Didn't break a thing! I hit manual release and turned left with a long screw driver. Tight fit on arms behind black plastic in cargo area ouch.
Thanks all.
Ray
Gunner242
Dec 25, 2015 04:49 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
formula00ra
Sep 28, 2015 11:50 AM
ironbmt
Sep 27, 2015 06:00 AM
