windshield washer tank
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
Not sure what subject this would go under but here it is....
all I have to do is extend the wiring and water line
I installed a 93 camaro washer tank what do ya think?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
hmmm thats neat havent seen that before. good way to hide the ugly tank in a car with wipers
Car: 1992 Camaro RS
Axle/Gears: Stock
Nice work. You should consider something like this for the overflow tank. It's a lot smaller and easier to hide.
http://store.summitracing.com/partde...5&autoview=sku
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Been there done that.Posted a thread here about a year ago.May still be able to do a search if you like.
Car: 89 iroc
I saw your pic but you didn't show what you did with the tanks, and I am looking into that tank from summit, but I thought it had to be a recirculating tank??????
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I posted a thread on here about a year ago.Anyway If you click on my user name,then click on "find more post by 841LE".You should find the threa i posted.The washer tank is under the Cover just ahead of the radiator.The overflow tank is under the battery.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I dont have a pic anymore, but i thought there was one posted in the thread.Both tanks are from a 4th gen F-body.They are both mounted in the same manner as on 4th gens.
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Re: windshield washer tank
I am doing a LT1 Swap in to my 92 Camaro, The washer tank looks good, I am about to do the same. I am in the process of using a 4th gen overflow tank/batter mount will have it done tomorrow, will post pics in the next few days and start a new thread.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Ya, I did that mod a while ago. I have the 4th gen coolant tank, just been to lazy to put it in.
Bohemian
Aug 15, 2017 05:11 PM
