82-84 Fiberglass Hood?
Old Nov 14, 2006 | 04:41 PM
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
Could anyone tell me which year hood it is? Also how much lighter would it be then my stock Iroc-z hood? Anyone have any opinions on how those hoods look? Pictures? I want a lighter hood, but don't like the big bulkyness of a cowl or SS hood. I want a more stock look. TIA, Nick.
Old Nov 14, 2006 | 05:38 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I think they are 82 Z only hoods, here are some pics. I know it's lighter but how much lighter I couldn't say. I have also heard of problems with its attachement points under the hood as you can see in the bottom pic.
Old Nov 14, 2006 | 06:14 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
weren't they on the 83 and 84's too im not sure and yes they do have problems with them seperating, and flying off someone I know had this happen to them not a pretty site
Old Nov 14, 2006 | 07:32 PM
EvilCartman's Avatar
Car: '82 Z28
I have my stock one sitting in the garage and it's right around the same weight as my Harwood cowl hood. The cowl hood might even be a little more heavy.
Old Nov 15, 2006 | 09:36 PM
CrazyHawaiian's Avatar
Car: too many ...
Here's a pic of that hood on my 89 IROC-Z
If I can find the right kinda scale I'll weigh it and compare it to a stock IROC-Z hood w/ louvers and the stock flat RS hood. Had to take it off the car anyway to swap the motor.
Old Nov 15, 2006 | 11:25 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Can anyone answer this question of mine ?
https://www.thirdgen.org/forums/fabr...-z28-hood.html
Regarding that hood.
Old Nov 16, 2006 | 12:45 AM
Car: too many ...
Sorry but I cant really help because my hood didn't have any of the "ram-air" stuff when I got it. It just had two plates over what I thought would be openings, but like you said it ended up just being two holes for screws. I don't know if maybe this means the one I got was never a "ram-air" hood or maybe it was all a joke? I dunno, but I just cut those two vents out completely.
Edit - Here is a closeup of the cutout vents (from the picture in my signature image)
Old Nov 16, 2006 | 12:59 AM
Car: '82 Z28
The crossfire hoods had vacuum operated flaps that would open to let fresh air in through the hood openings. The non-crossfire hood just had a couple of plates bolted in place.
Old Nov 16, 2006 | 02:09 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
nope, i have an 83 Z hood, its steel, but hey it was $20, im not arguing.
it has the flaps for ram air though.
Old Nov 16, 2006 | 01:27 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Could you guys post a pic of the flap set up ? Where is the vac line hooked up to ?
CrazyHawaiian, did you put any mesh in those openings or just leave them open ?
Old Nov 16, 2006 | 08:35 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The hood flaps are actually electric solenoid controlled by the ECM thru the TPS but the setup can be modified to work just off throttle position.I'll post a picture of the underside of my '83 Z8's hood for you tomorrow.Also if you use one of the factory composite hoods make sure you use hood struts for them and not for the steel hood.If the wrong strut is used it will lead to cracking in that part of the hood.
Old Nov 17, 2006 | 12:18 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I found a factory SMC hood in a junkyard and I paid $40 for it. It's sitting in my hallway awaiting paint. But I did some research on the SMC hoods. The 82 Z28 and 83 Z28 had these hoods. But only the 83 hoods had the separation problems due to the glue they used. Apparently GM got a new supplier for glue for the 83 changeover. And the 83 glue was a bad batch. So the 83 SMC hoods got recalled and replace by steel hoods, which continued through 84. So if the hood is off an 82 car, then it never got the recall. But if you find one, why not have the body shop check it out, maybe re-inforce it somehow. Luckily, the car I got my hood from was an 82 Z28. So I'm not worried about it.
On a note:
The Firebird powerbudge hoods had some that had a similar flap system for the cowl on some of them.
Old Nov 20, 2006 | 11:10 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Not sure which year mine's from, got it at the junkyard.
I should be able to use my stock struts though, simply because they're rather shot right now, I can't keep the steel hood up with them. But if I get a problem, I'll simply remove them.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
