hood weight?
Old Nov 30, 2006 | 01:10 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
hood weight?
would a fiberglass lift off weigh significantly less than a bolt on fiberglass hood. please take in to account the hinges and latch. right now it is a tuff decision what hood i want.
Old Nov 30, 2006 | 01:22 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
If you drive your car a lot, or live someplace where the temp changes a lot, get a bolt on hood. Lift off hoods are for racers, not for the street. I garontee you, there is a good reason why they call it a race part. Its cuz it isn't made to take the abuse of the street. They are really thin, and prone to have the paint on them crack. The hinges wiegh maybe 2 lbs and the other crap is like maybe a few ounces, haha. There is no weight to save there at all. Just pay the extra $ and get a real hood, not a race hood. The difference is maybe 5-10 lbs at the most anyways, IF THAT....
GET A BOLT ON HOOD
Old Nov 30, 2006 | 01:40 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the diff depends on the builder and model, but total diff is anywhere from 3 to 7 pounds. this depends more on how the hood is constructed more then the weight of the hood latch and hinges...
alot of the super lightweight pinons are not a good idea for the street..
if your car sees regular street usage at all, id reccomend a bolt on.
Old Nov 30, 2006 | 02:05 PM
z28z34man's Avatar
i was planing on a bolt on but if there would have been a 30# weight saving i might have went pin on. i don't drive it too much it might get 1000 miles a year.
Old Nov 30, 2006 | 03:16 PM
Engine: LS3
wow, only 1000 miles a year, than yeah, do whatever you want. That is practically nothing. If it is parked like that all the time, then get a pin on and save the $. If $ is not that big of an issue, (you do have a car that you barely drive) so I assume it isn't that tight, you might as well do it the right way and get a (streetable) bolt on hood.
My Cervini 3" is a bolt on and is very well constructed.
Old Dec 1, 2006 | 08:36 PM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
i have a harwood lift off and its super light!!! i drive about 1000 miles a year also and haven't had a problem. my biggest bitch is removing the hood to change oil check fluids but the great part is if you work under the hood alot you pull 4 pins and its off and you dont need to realign the hood when your done.
Old Dec 1, 2006 | 11:29 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
mine takes 2 people to remove the hood everytime I want to change something on it.
Old Dec 6, 2006 | 09:14 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
82 TransAm hood // Formula Hood weight
Whats the weight of this hood ?
thanx
Old Dec 7, 2006 | 09:08 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
my fiberglass bolt on hood weighs ~35lbs, and the lift off hoods weigh around 20lbs, i wouldn't say that the 15lbs is worth the hassle, and i've had both.
Old Dec 7, 2006 | 09:18 PM
xpndbl3's Avatar
Car: 1984 Z28
i doubt my lift off even weighs 10 pounds honestly. it's super super light, maybe i'll put it on a scale someday, very thin and no bracing....yea it's light.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Damon
Sep 26, 2015 04:29 PM
