fresh air vent leak
Old Jan 16, 2007 | 10:40 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
fresh air vent leak
ive been meaning to post this for a while, but any time i wash my car or if it rains, i get water on the driver side floor board. im assuming it comes from the "crotch" vent. is this an easy fix or do i have to get inside the dash to fix it?
Old Jan 17, 2007 | 05:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd be interested in a fix as well.
JamesC
Old Jan 18, 2007 | 11:34 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
The what vent??
I thought I knew every square inch of these cars. Please elaborate on this "crotch vent" while answering his question above.
I assumed my heater core just leaked through the vents and ended up there after a good right-hand turn.
Old Jan 18, 2007 | 10:36 PM
pepper6181's Avatar
Car: 91 Camaro RS
Engine: 3.1L
my car is doing this on the passenger side. T-top seals are bad.
Old Jan 18, 2007 | 11:17 PM
Gramps's Avatar
Car: 87 Camaro IROC
i dont think the T-top seals are bad, i think its a poor design, thers a gab between the door and the edge of the seal housing. that 1" gap allows water to leak thru. i managed to fix everything else but to fix that you need to fill that gap up w/ some fiberglass or something.
Old Jan 19, 2007 | 05:00 AM
JamesC's Avatar
I assume this this the wire mesh business that runs across the top of the cowl. My leak somehow filters down through the dash area and drop at the driver's feet.
JamesC
Old Jan 20, 2007 | 12:39 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Crotch vents I *think* are on F-bodies without AC. Two little pull out vents on the driver's side. If there is a leak there (and it's not the t-tops, mine leaks at the t's, and I have no crotch vent) then it seems that seems like it would be a system design. Maybe some leaves got down into your vent system and are clogging the water drain that's in there somewhere. Other than that, I dunno what to tell you. I'll look in my manual, whenever I find it.
Old Jan 20, 2007 | 08:28 AM
drdave88's Avatar
Engine: 6.0L
yes, those are the vents im talking about, i can see under the dash where it comes from, but i cant really see how it would be leaking through there, just wondering if anyone else ever had this problem. and i dont have t-tops on mine.
Old Jan 20, 2007 | 03:58 PM
Axle/Gears: 3.27 BW
Yea. Looking through my manual (87 Factory) it looks like you might just have something stuck up in your vents preventing the water from draining out. With the cowl air input, you'd assume they'd setup a way for water to drain out. Whenever I get a hose I'll spray some water down in there and see where it comes out.
Old Jun 2, 2012 | 10:40 PM
dank0702's Avatar
Car: 1985 Camaro Z28
Engine: 305 with 4BBL
Transmission: 5 Speed
Re: fresh air vent leak
What are those vents called? I have one for the drivers side but just a hole were the other one would be. Where those for cars without a/c? I have RPO code C41 which is C41 : HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN. Does that mean mine came with or without a/c? Because I do have the A/C with what looks like original hardware but thought it was odd that I have those pull vents under the steering wheel.
Old Jun 3, 2012 | 04:54 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Yes, C41 has those manual fresh air vents. C60 doesn't. At least you guys have/had the vents in place. The IROC doesn't and all that's left there is a big gaping hole. Every time it rains, I end up with water in the driver's floor. Good thing it's already been 1. replaced, 2. sealed with POR-15 or similar, and 3. permanently sealed with DupliColor BedArmor over the top of the POR or whatever it is. I need to get my hands on a piece of steel to put over the vent hole and seal it. Don't want the fresh air vent (too many parts to obtain that are difficult at best to find), and I don't want the gaping hole there, either, with the 4th gen dash I plan putting in with its heater box (which had A/C and never heard of the fresh air vents).
Old Jun 3, 2012 | 10:07 AM
dank0702's Avatar
So does that mean someone added all the A/C parts to my camaro and it wasn't factory installed?
Old Jun 3, 2012 | 10:22 AM
Engine: 2.7L V6
Axle/Gears: 4.41
If you have the car's original RPO sheet and it shows C41, it didn't have C60. It's an either-or thing. You can't have both, because C41 was heat/vent only and C60 was heat with A/C. Yes, someone added it at some point, probably because of the heat during the summer due to the hatch.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
LittleFranks
Sep 17, 2015 12:22 PM
TheExaminer
Aug 26, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
