Front end of the car rattles...
Old Jan 23, 2007 | 12:18 PM
Dima's Avatar
Car: 2002 Pontiac Firebird (R.I.P 1992)
Engine: 3.8L Ram Air V6 3800 Series
Transmission: 5spd
Axle/Gears: Unsure
First off I drive a 92 pontiac firebird, V6 4 speed completely stock right now. My problem is every time I hit a bump or turn into a parking lot I hear a metal on metal rattling sound from the front on the passenger side. I tested this by taking everything out of my car so all that was left was the car itself.
I broke the bracket that holds the control arm/cradle to the unibody frame and believed it was that, and got it fixed, but in the front on the passenger side I still hear a metal on metal rattling sound. Could this be my ball joints or bushings, and if I replaced them would it fix the problem? The car is 14 years old stock in great condition so I wouldnt be suprised if some of the rubber was shot. Although my mom's 92 firebird did the same thing.
If you can answer this it would be a great deal of help =)
Old Jan 23, 2007 | 12:44 PM
Gramps's Avatar
Car: 87 Camaro IROC
sounds like a ball joint, take it to a shop and replace both ball joints and have them do a wheel alignment too.
Old Jan 23, 2007 | 04:08 PM
Dima's Avatar
Transmission: 5spd
Axle/Gears: Unsure
Thanks =) Just wondering do you know if those are expensive or not?
Thanks again.
Old Jan 23, 2007 | 04:27 PM
Gr89RS's Avatar
Car: '02 Z06
It's your front sway bar bushings..it's a common problem that develops with these cars. To test it, get under the car and smack the sway bar..if the bushings are toast, the sway bar will have play in it and make the noise described.
Old Jan 23, 2007 | 07:36 PM
Gramps's Avatar
Car: 87 Camaro IROC
ball joints in canada are 50 buks a pop for some good quality ones. in the states they could be 20 buks. canadian prices are way off from the rest of the worlds.
Old Jan 23, 2007 | 09:57 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Mine used to do that when I turned left hard. After I swapped out my rear end with one from an 84 Z the sound mysteriously went away, even though the sound sounded like it was coming from the front. Go figure. Never figured out the problem though.
Old Jan 24, 2007 | 02:01 PM
Dima's Avatar
Transmission: 5spd
Axle/Gears: Unsure
How about I replace both ^^ and yeah ill test that.
Too bad my car was made in cali... I live in Utah so like, the cold cracked my dash so I gotta find a place to order one of those from too. Other than that I'm good ^^ But I'mma change the color from a blueish green to black or blue.
Old Jan 25, 2007 | 08:38 PM
90tararebird's Avatar
Car: 1990 trans am
Engine: 350 tpi
I can't believe it a third gen with a rattle!
Old Jan 26, 2007 | 03:50 PM
Dima's Avatar
Transmission: 5spd
Axle/Gears: Unsure
Lol i wish my car didnt rattle i wanna restore it to full stock before i mod it.
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
