ground effects
Old Mar 5, 2007 | 11:31 PM
jt2007's Avatar
ground effects
hey guys, i was wondering if the rocker panel ground effects from a 91-92 rs would fit on a 83 z28. thanks
Old Mar 6, 2007 | 01:56 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
anything between 82-92 will fit. just depends how much fabrication you want to do. Bolt holes might be different so you would have to drill new ones and fill up the old ones. plus are you just doing the rocker panels? what about the rest of the ground effects package? just think theres more to it then a simple yes or no. know what i mean?
Old Mar 6, 2007 | 04:05 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have a pair of factory original and correct nice shape rocker GFX panels from an 82 Z28 i parted out last fall, i have no use for them at all
interested ? make offer or trade me something out of an 82 83 84 bird, i need all kinds,
heres a pic of the Z28 before i stripped it
good luck
Old Mar 6, 2007 | 12:15 PM
90_T/AGTA's Avatar
Car: '90 GTA
They bolted up on my 84 Z28 no problem
Old Mar 6, 2007 | 02:12 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok awesome, i wasn't sure if they would but great
Old Mar 6, 2007 | 09:22 PM
SDCal7's Avatar
92 aero panels
I'm doing the same thing. 92 front piece and side/door panels on my 89 Iroc vert. Body shop called and have a problem with fit. I hope it's just a matter of redrilling the bolt holes. So they must fit, right?
Old Mar 7, 2007 | 12:14 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
different holes and then they are supposed to work yes
Old Mar 7, 2007 | 01:32 PM
Night rider327's Avatar
Car: 1988 Camaro
I put 91 side ground effects on my 88 that had ground effects already. I had to do some fab work/mods to make it fit. I don't have pics of the mods on my webshots page but I do have all the pics on my PC. If you need them, when I get home next week I can send them to you.
mods to make them fit..
Hole on fender had to be drilled larger, around 3/8" and use a large washer behind the hole
there's a metal pc. along the rocker that the ground effect sits on, and screws to under the bottom. At the rear of that metal flange I had to cut a small portion off to let the 91 GFX go all the way against the car.
Under the bottom of that I had to drill all new holes for the small sheet metal screws to fit cause the 91 GFX has the holes around 1/2" off from where my 88's was.
At the 1/4 panel, I had to drill a new hole for the stud on 91 GFX to fit through.
If I remember right, the part on the door needed no mods to fit.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
