T TOP GASKETS??
Old May 20, 2007 | 07:24 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
Engine: 396 LT1 Stroker
Axle/Gears: Ford 9 Inch w/ 3:70 Gears
T TOP GASKETS??
Hey guys does anyone know if or where you can get The outer T Top gaskets that hang over the door windows. They are more like a strip. They always seems to come apart and bend at the ends.
Old May 23, 2007 | 11:06 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: T TOP GASKETS??
OUTER T TOP SEALS are what you are looking for. There is always a set for sale on ebay. Also http://www.1aauto.com/1A/Weatherstri...SC00083/419753
I'm sure one of the sponsers carry them but, I beleive you can still get them from GM.
Old May 31, 2007 | 01:00 PM
RobAtPace's Avatar
Car: 1989 Iroc-Z
Engine: 5.7 350
Transmission: auto
Axle/Gears: stock
Re: T TOP GASKETS??
Hi,
just so you know, that is incorrect.
I, like the original poster, am looking for the rubber sashes that hang off the outside of the t-top and cover the glass (rubber attaches from outermost part of t-top and remains outside exposed to the elements- hence why it tears).
I went ahead and ordered the linked part above, and after confirming part #'s, names, and actually holding the shipped part in my hand... I have determined that this seal is for the glass connecting to the t-top.
this incorrect part is also known as the t-top side rail hatch seal.
I ordered it, and now have to ship it back. I am looking for this rubber sash and will report back if i find it.
Old May 31, 2007 | 01:13 PM
RobAtPace's Avatar
Car: 1989 Iroc-Z
Engine: 5.7 350
Transmission: auto
Axle/Gears: stock
Re: T TOP GASKETS??
this is an image of what I am looking for and what i believe he is looking for:
Old May 31, 2007 | 01:27 PM
MajorPayne's Avatar
Car: 1987 Red Camaro Iroc
Engine: Stock lb9 305 TPI
Transmission: Th700R4
Axle/Gears: 3.23 posi, disc brakes.
Re: T TOP GASKETS??
Are thay neccesary anyway? This question has been bothering me for a week Can I just 'shave' the old ones???
Old May 31, 2007 | 05:38 PM
cdoyle's Avatar
Re: T TOP GASKETS??
I think they are meant to help keep water from dripping on where the window meets the weatherstripping on the top.
I'm not sure tho, but mine is doing the same thing. Are they even replaceable?
Old May 31, 2007 | 06:12 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: T TOP GASKETS??
Originally Posted by wildjeff
I just bought a set from gmpartsdirect.com,
Part numbers are;
Side Rail Seal RH 10198352
Side Rail Seal LH 10198353
The original ones are a firm rubber, the new replacement ones from GM are plastic. You can take the trim off the top and replace it but it’s a pain, at least mine where.
Those are what you want. I got that from this thread:
https://www.thirdgen.org/forums/body...im-needed.html
I bookmarked it so I wouldn't lose it when I want to order them
It looks like they're 50 bucks, but probably well worth it to get rid of old faded ones.
Old Jun 1, 2007 | 03:21 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: T TOP GASKETS??
Ahh Sorry about that I missed "hang over the door windows" part. I shaved those at the front on my car just a tad to keep them from hitting the window as it was pulling down like the one in the picture, I still need to replace them, but my orginal seals still do not leak except in high pressure car washes. Although when I repaint it probably next summer I will be replacing all the seals as I plan on taking the car partially apart for the paint job. This summer is drive train as I am at 210k miles.
Old Jun 1, 2007 | 07:03 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: T TOP GASKETS??
The prices of weatherstripping is just beyond rediculous. They act as if the rubber used to make them is almost extinct.
The prices of weatherstripping is just beyond rediculous. They act as if the rubber used to make them is almost extinct. I can buy 4 new tires for less that a t top kit!
Last edited by PneumaticTire; Jun 1, 2007 at 07:04 PM. Reason: Automerged Doublepost
Old Jul 21, 2007 | 04:02 AM
ATCharming's Avatar
Car: 2000 SS
Transmission: a4
Re: T TOP GASKETS??
i have the exact same problem. what happened with mine is, that flap hung over, and my window caught it while going up. now my window motor is screwed up from pushing against that pice all the time and now my window doesnt go all the way up. id like to know all this same info
they are VERY necessary. my gf gets rained on cuz these things are ****ed up on my car
i hope they are replaceable!!!
Old Apr 10, 2010 | 08:32 PM
wehrlebird's Avatar
Car: 87 T/A
Engine: 383
Axle/Gears: 373
Re: T TOP GASKETS??
Hey, my 86 TA leaks like crazy through the t tops. Do you know which gaskets are the ones that notoriously go bad and leak?
Old Oct 14, 2010 | 08:08 PM
Schme2's Avatar
Re: T TOP GASKETS??
Sorry to hijack - only because I haven't found a post on this, but my window is actually the one leaking not the T-Top....as ATCharming said, my window catches on the T-Top gasket as I shut the door, now my window doesn't seal like it should and it leaks like a champ due to the window not going all the way up to seal properly. How do you fix that??? Don't want to waste money on something like the T-Top seals when they are still good!
Old Oct 15, 2010 | 12:16 AM
puma1552's Avatar
Re: T TOP GASKETS??
Looks like GM Parts direct no longer carries the part number ending in 53, just the one ending in 52. Dang.
Old Oct 15, 2010 | 09:06 AM
1Aauto's Avatar
Former Sponsor
Re: T TOP GASKETS??
I have the Firebird T-Top Drip Edge weatherstrip in stock.We should have the plastic drip edges any day now.
Firebird T-Top Drip Edge Weatherstrip
1992 Trans Am
May 10, 2023 07:19 PM
xxx3man`
Sep 23, 2015 10:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
