Fender removal
Old Jun 4, 2007 | 01:20 AM
rmason92's Avatar
Fender removal
I just want to say I did a search first and didn't really find the help I was looking for. I need to remove my Drivers fender, I have the hood bolts off but now i'm stuck how do you get the bolts that hold the fender to the front nose/bumer? Anyone got diagrams or pix of where to start. Thanks in advance.
RON
Old Jun 4, 2007 | 01:32 AM
sicc87's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: auto 700-r4
Re: Fender removal
remove the tire.. and the shield.. and stick your head in there.. you'll figure it out.. there are a few bolts in there.. you wont miss em.
Old Jun 4, 2007 | 03:37 AM
rmason92's Avatar
Re: Fender removal
I'll give it a shot I got the fender shield off but not the tire, so it isn't hard after that?
Old Jun 4, 2007 | 11:09 AM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
Re: Fender removal
its really simple once you can see whats going on under there. there are 2 studs that hold the fender to the bumper as you mentioned. when i took my fender off i had the light buckets out and the nuts are easily accessible although I'm sure you can get to them from the wheel well.other then that there are a few bolts along the top and bottom of the fender itself. good luck
Old Jun 4, 2007 | 11:23 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: Fender removal
theres 4 actually
Old Jun 11, 2007 | 09:00 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: Fender removal
hey i got a question, what size sockets do i need to take the bumper off?
Old Jun 11, 2007 | 09:08 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: Fender removal
You serious...?
Old Jun 11, 2007 | 09:43 PM
Re: Fender removal
with it being my first time, id say i was pretty serious
Old Jun 11, 2007 | 10:52 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Engine: 305 V8 carb'd
Re: Fender removal
You'll need mostly a 10 mm
Old Jun 11, 2007 | 10:57 PM
Re: Fender removal
thanks
Old Jun 12, 2007 | 09:44 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: Fender removal
You can also go in by removing the headlight assemby (on firebird), or through the wheel well after removing the shield. They are equally annoying. I would not recommend going through the shieild area, because the shield is held on two ways. With a few bolts that secure it to the inner fender. As well as those plastic push in type "bolts" that secure the shield to the fender. Once the platic ones are removed, you usually need new ones.
SO i would advise going in through the headlight area.
1) Remove all the bolts up top with a 10mm. I beleive there are 3. Two on top, one beside, facing forwards.
2) Turn on the headlights, and disconnect the battery. This will leave the lights popped up, and turned off so you dont lose battery life.
3) Use the "****" to manually drive the motor, and look through the opening below the headlight and bumper, and keep turning the headlight down, untill you can see the TWO (2) bolts that hold the bottom part of the headlight.
4) At this point, you will need a BIG extension, i used 2 long ones. And a universal jointed socket. Not sure what its actually called, but it has a joint and it bends.
5) Then what i did was attach a magnet, to the extension, so the bolt doesnt fall off when i pull it off. (it also helps ALOT on reinstallation). THen you just undo the bottom two bolts, and pull the headlight assembly off.
6) Unplug the actual bulb, so you can get the assembly out of the way.
7) Feel for the bolts where the fender meet the front bumper. They are nuts actually, so you will need a DEEP socket. DONT FORGET THE ONE WAY AT THE TOP!!! You cant see it, but its there.
8) Having the battery out (or the charcoal canister for the driver's side), and going in through the side cavity helps alot. You will need various extensions to get to them all.
Hope that helps, i got pix too if u need em.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stroopwafel
Sep 11, 2015 06:38 AM
