How do i change the Fog light bulb?
Old Jul 6, 2007 | 02:57 AM
Tobashadow's Avatar
88 irocz with factory fog light's
Old Jul 6, 2007 | 03:27 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: How do i change the Fog light bulb?
Okay, there's a right way and a wrong way to do this. One is MUCH MUCH MUCH easier, but you might get grubby prints on the bulb, EXTREMELY shortening it's life. The right way is to get under the nose, unbolt the plastic deflector panel, find the bolt that is actually the shaft of the fog light, unbolt it, pull it out the front, twist, remove bulb, replace bulb, twist back in, and rebolt.
The wrong way is see if you can jam your hand back there (maybe remove the grille) and if you can twist and remove the fog light, do it. Put the new one in, and try your damndest to not get fingerprints on the bulb while you squeeze it back there.
Old Jul 6, 2007 | 07:30 AM
atomicskr's Avatar
I just took my air filters out and reached down through the air box... a bit of a feel job but not too bad. Definitely wear a latex glove when you do it..... otherwise you'll be redoing it very soon.
Old Jul 6, 2007 | 06:55 PM
Tobashadow's Avatar
Well that was fun.
I unbolted the air dam then took out the two bolt's that hold's the light in and pulled the whole housing out and swapped the buld.
But while i had it out i removed the light shield inside the housing, then i went ahead since it was just two more bolt's i pulled the other light and pulled it's shield out also.
I also found my fog light relay finally, it was behind the horn's inside the fender?
Odd location but i pulled it out where it's supposed to go and did the green wire mod to it.
Now as i bask it bright full time glow i say thanks for the tip's.
jaridjohn
Jul 8, 2024 03:49 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
