fastest way to empty the gas tank
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
i have a little under half a tank of gas in my bird thats sitting on jack stands, i want to take the gas out and fill the tank with fresh gas with stablizer, i didnt have a hose long enough to suck it out and i dont want to burn out the pump cranking it wiht the line going into a gas jug. any suggestions are apprecaited
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: fastest way to empty the gas tank
go buy 4 feet of hose and shove it down the filler neck, or hotwire the pump until the gas guage almost reads completely empty and just fill it back up
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
well the absolute fastest would be drill a whole in it...Id by soem hose.. Its really not all that expensive.
Engine: 305--
Axle/Gears: 2.73--
To anyone on the board that reads this... never let your friends talk you into doing things with fire... You'll end up like me... in the hospital but you get one hell of a story to say at school...Just remember if you burn your face.. Neosporin is your best bet.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
go to a marine supply place and buy a oil suction pump for a boat
Car: 89 Formula
Engine: LB9
Axle/Gears: 9 bolt / 3:45
If you disconnect the fuel line at the fuel filter, most of the gas will drain out. You can also disconnect the return line, which may be easier, and most of the gas will also come out. Drain it into a can. That is how I drained the gas when when I pulled the gas tank. Be careful if the lines are rusty-I ended up having to buy new metal lines because of the corrosion. When I tried to disconnect the lines at the fuel filter, the nut was siezed to the tubing and tubing tore when I turned the nut.
ive tried sticking a hose down into my gas tank but it gets to a certain point and always gets stuck and won't reach the tank.. i was using fairly thin tubing too, so i dunno how well that will work for you..i kno i have yet to be able to siphon anything at all outta my tank
Car: 1989 Trans Am
Engine: 5.0 TPI
yeah i tried with a few pieces of hose i jammmed inside one another it was prob around 4 feet long but i still didnt get any gas, im gonna try and dissconnect the line at the filter.
I used a cheap electric fuel pump and mounted ot to a 2x6x 12 inches long and used about 6 feet of hose and pumped it out that way. I also used a short piece of steel line on the end of the rubber hose so it will out a little more weight on the hose and so I can tell when it hits the bottom of the tank.
Bohemian
Aug 15, 2017 05:11 PM
