Modifying a Sport Coupe
Old Aug 6, 2007 | 01:20 PM
camarosc86's Avatar
I have this idea to fill in the three holes on my coupe, I think it would look sleek. I need to get a new front bumper and I am going to re-paint the car as well. Instead of trying to tell you, I will just post pics (Don't mind the unwashed car):
Car now:
Bumper idea:
Could I use bondo/body-filler on the indents and paint over? Any other ideas?
Old Aug 6, 2007 | 01:28 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Modifying a Sport Coupe
I take it you want to keep the Sport Coupe's front bumper and not change to a Z28/IROC/RS(these don't have the slots).To do what you want it would be best to use an old nose that doesn't have the slots for the material then graft over the slots.
Old Aug 6, 2007 | 01:29 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I personally prefer the fiberglass filler myself.
I think the holes are okay, though. You will see more of a change with a different set of wheels.
Just my opinion...
Old Aug 6, 2007 | 01:30 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I wouldnt use bondo, it would start to crack if the bumper flexes
Old Aug 6, 2007 | 01:38 PM
camarosc86's Avatar
I picked a sport coupe because I think they look slimmer than Z28s/IROCs. But I'm also not a huge fan of the holes(Although I could live with them).
Lowered slightly with 16" IROCs or 91-92 Z28 wheels would look nice and change the look of the car.
Old Aug 6, 2007 | 01:45 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Do the wheels first; you'll probably get a new opinion of the holes afterwards...
Old Aug 6, 2007 | 06:24 PM
L0tuS's Avatar
idk man its just going to make the car look like it got the GFX knocked off cause basicaly its what it is, and the car will always look like its sitting too high. why dont u want to just switch out the bumpers? if u still want the slimmer look used a front nose off an early z28
Old Aug 6, 2007 | 06:44 PM
darrencarr's Avatar
Car: 87 sport coupe, 85 Z28, 93 S10
Engine: 179ci MPFI,LG4 (soon L98), 4.3L TBI
Transmission: 700r4, none (soon T56), 700r4
Axle/Gears: stock, 3.23, stock
the holes are there for air intake, if you pay attention the RS and Z28 noses have lower hole under the liscense plate to redirect air up to the filters. The SC noses dont go down that low so they have to have the holes to breathe properly.
Old Aug 6, 2007 | 08:13 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I was thinking the same thing. I have an 86 and I would leave them alone. The car needs the holes for air intake.
And the suggestion anout the wheels is correct. You will see the fastest change in apperance this way. Only changing hoods goves a more dramatic effect. You may not get the desired effect if you cover the holes and your car will run hotter.
Old Aug 6, 2007 | 08:36 PM
camarosc86's Avatar
The early Z28's are not slimmer and they are square, they would look even more blunt. And if it is lowered it will not sit too high. A gfx car without gfx looks bad in the front because it has no lip under the grill, just a flat line under the grill hole with exposed bolts.
In regards to airflow, the stock intake snorkel is nowhere near those holes. In fact it is bolted near the hood opening. The radiator is hit with air from the grill and the air dam(the biggest factor). Those three holes are nearly pinched closed (I just went out and felt them) in the back so they don't worry me from a technical standpoint.
Not that I'm saying you're wrong if you don't like it aesthetically, but it's my car and it isn't a radical project, so does anyone have advice other than fiberglass body filler?
Someone suggested body filler for the holes in the front valence in the japanese body kit thread.
Old Aug 7, 2007 | 04:09 PM
darrencarr's Avatar
As far as air intake heat wise yes you'd be fine but I was talking about air intake in the air filters. Thats where the car gets a lot of its air that it uses for combustion. You probably won't notice a dramatic effect in power cuz you're not starting with much (135hp, 165 Ft lb) but you'll lose the cold air intake effect.
Yeah I noticed the difference on my sport coupe when I put 1982 Indy pace car rims and hood on my 87, I think it really sets it off.
Old Aug 12, 2007 | 05:18 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I think the three slits on the bumper look cool IMO.
Old Aug 12, 2007 | 08:02 PM
darrencarr's Avatar
yeah mine used to look like yours camaropunk only red and black its been a while since I've seen a pretty sport coupe, wrecked mine a few years back and it was really pretty. I'm gettin it repainted at the end of the summer (I hope.) Anyways yeah I've been debating whether or not I wanna get set of Z28 GFX but I like those slits too, maybe ill only go after the spoiler.
Old Aug 30, 2007 | 10:15 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Yeah, i always here sport coupes are everywhere but I havent seen any others in my neck of the woods or surrounding areas..........Ive seen some aftermarkeet ground effects on ebay and you can retain the stock bumper i think they are called xenon or something like that, i wouldnt add them, but they dont look bad.
Old Aug 31, 2007 | 10:25 AM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
O and we didn't say anything about the air going through the holes to go to the engine..... we were saying that it will get to the radiator to help cool the engine.... but if you have to use anything i would say fiberglass or the original material.
Old Aug 31, 2007 | 08:40 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Um, no. Actually, the 85-92 non sport coupe setup has ducts behind the fog light area/grill on either side of the plate. They direct the air to the radiator, and actually block air going to the bottom of the air cleaner assembly. The only thing below the plate is the ground effect.
The three slots are purely cosmetic and won't make a bit of difference if they are blocked. They open to the same air space as the holes behind the grill on either side of the front plate.
Old Aug 31, 2007 | 09:34 PM
v10viper04's Avatar
Engine: LT1, L99
act like you know everything......... You may be right or not....
Old Aug 31, 2007 | 10:16 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I love sport coupes... But a paint job, some new wheels, and louvers for the back window, you'd be stylin'.
Old Aug 31, 2007 | 11:28 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
I've owned both styles, parted out plenty of the cars. It's not a matter of knowing everything. That's just the facts of the way the cars are designed.
Old Sep 1, 2007 | 05:28 AM
darrencarr's Avatar
Or what would be really cool is to find the nearest plastic welder and get him to weld in patches.
Old Sep 3, 2007 | 07:32 PM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
I guess I feel opposite. I bought my sport coupe 20 years ago, and until 2000 got all the IROC groung effects, motor, axel, and wheels. I always wanted an IROC.
Old Sep 3, 2007 | 10:54 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Same here, I wanna get a new bumper cover for my SC for an IROC replica
Old Sep 3, 2007 | 11:02 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Thats cool, but you cant really call it an iroc if its not, its kind of like buying a cheap shoe and putting on a nike patch, looks ok but in the end its not real
Old Sep 8, 2007 | 10:07 AM
camarosc86's Avatar
You're right. Even the grill holes aren't a huge deal if the air dam isn't gone or broken. All those people with home-made ram air scoops in the grill on TPI's seem fine.
Old Oct 11, 2010 | 08:34 AM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
This is the best view of my car with my z28 Gold rims on it, i have a sport coupe, and yes please laugh at my retarded friend
Old Oct 11, 2010 | 12:31 PM
Apolo's Avatar
Car: Camaro 1987
Engine: V6 2.8l MPFI
Also, you can put a z28 82-84 nose, without the chin spoiler, it would look more agressive
Old Oct 11, 2010 | 01:09 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
The car looks good. Any side profile shots with the rims? I am biased since my LT pretty much is the same car like yours. Although, I did gut the stock suspension and added 1LE springs, Bilstein shocks and struts, 36mm & 24mm sway bars, steering box brace, polygraphite bushings, new boxed trailing arms and new panhard rod. So a bootleg IROC without ground efffects. Oh yea, and the Ronal 17" R15 Firehawk wheels. And the wheels did make a big difference.
Old Oct 11, 2010 | 02:27 PM
Oelmuvun's Avatar
Car: 1986 Firebird Trans AM
Engine: LG4
Old thread from 2007 is old.
Either way, I personally like the holes up there!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
LT1Formula
Oct 8, 2015 08:34 PM
