Mounting tips and help for a high rise spoiler (91-92 Z28)
Old Sep 1, 2007 | 03:03 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
I dont have any instructions to mount the high rise spoiler. I kinda have an idea about how to mount and where it lines up to mount. I just wanted to know if anyone had any tips or could show me some pics of theirs so i could determine how to mount mine. I looked but i dont see anything that will help alot Thanks guys. -Matt
Old Sep 1, 2007 | 04:30 PM
sp63
Guest
Posts: n/a
Re: Mounting tips and help for a high rise spoiler (91-92 Z28)
where are you at in ky?
dont suppose you bought that car from larry?
Old Sep 1, 2007 | 05:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
just kind eye ball where it goes, there should be a rubber gasket in between the spoiler and the hatch which allowed us to tape to the hatch and drill holes based off that gasket. If you don't have the gaskets then get some weatherstripping foam with tape on one side and cut to shape. Would be found at a pep boys, etc for use on bed caps for pickups, door seals, etc etc.
Old Sep 1, 2007 | 06:15 PM
19CAMARO85's Avatar
i have the gasket but i just wasn't sure if there was a die hard mounting method. thank man
"where are you at in ky?"
im just out side of owensboro. I bought the car from a woman.
Old Sep 5, 2007 | 08:47 PM
xsupermann69x's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
so i was looking to remove my spoiler of my rs and put a high rise one on my car so its not just going to be an easy unbolt then rebolt job? let me know. pm.
Old Sep 6, 2007 | 08:36 PM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
if you are replacing the exsisting rear spoiler for the high rise like I did, 2 out of the 4 holes line up, as for the other (2) I just took a can of spray paint and marked my other 2 holes and drilled them with a 3/4" drill bit, as for the ends I used self tappers.
Old Sep 7, 2007 | 01:52 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
In addition to what gordo420 said you will have some holes from the 3 piece spoiler that will need to be filled, preferably with a weld.
Old Jul 2, 2014 | 11:15 PM
joalva91's Avatar
Don't mean to bump this old thread, but i been thinking about doing the low lip spoiler to the high rise spoiler conversion just wanted to know which bolts line up? The ones in the middle or the outer ones??
Frozer!!!
Jan 19, 2024 04:55 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
Wife'sCar
Aug 22, 2015 01:46 PM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
