Rusted deck lid
Old Sep 12, 2007 | 07:00 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Rusted deck lid
Hey guys, the underside of my hatch deck lid has a good amount of rust on it. See the pictures attached. Im debating if I should just scrap it and throw a new one on or try and sand and grind it away. How much does a used deck lid go for?
RUST! (It looks like it goes down kinda deep cant see it in the pics though. It worries me bc its around those plastic caps so im guessing its all the way through.
http://images1.filecloud.com/589181/DSC02403.JPG
http://images1.filecloud.com/589187/DSC02404.JPG
Thanks.
Old Sep 12, 2007 | 07:49 PM
Brother Al's Avatar
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
Re: Rusted deck lid
Ouch! You could try to POR-15 it. Its petty bad & it is still gonna keep rusting on the inside. I'd just try and find a good replacement. Sorry!
Old Sep 12, 2007 | 08:14 PM
1984Z28HO's Avatar
Car: 1985 iroc
Engine: 305 H.O.
Transmission: 5speed
Axle/Gears: 3:73
Re: Rusted deck lid
take all the plastic plugs off and take a real corse disk and stand grinding i bet you can take most of it off, then get rust mort and cover that with por 15..
Old Sep 12, 2007 | 08:18 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Rusted deck lid
those plastic caps give access to the nuts that hold the spoiler on . i had mine off a couple mos. ago . [ looks bad to me ] take your spoiler off and you can better view the damage . seems to me when the car was last painted the spoiler was removed and no sealer put around studs that hold spoiler on . rains , water gets inside , no place to go = rust from the inside . i have not changed one so i can offer no advice except sealent , silicone , bath tub sealent , bubble gum ? around studs before re-install of spoiler . good luck .
Old Sep 12, 2007 | 11:31 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: Rusted deck lid
Looks just like mine
Mine was repainted at some point and I'm pretty sure they either forgot or did a bad job with sealing up the spoiler bolt holes. Unfortunately mine needs to be replaced.. yours doesn't look all that great. If you start grinding that rust out and it goes through to the other side you are probably going to have to replace it.
As far as I know, this is NOT something you can get anywhere other than used.
Old Sep 13, 2007 | 12:08 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
Re: Rusted deck lid
mine is rusted badly in the same places. Maybe there never was any sealant?
Old Sep 13, 2007 | 01:59 PM
blue_iroc_z28's Avatar
Car: 1987 pontiac trans am gta
Transmission: 5 speed
Axle/Gears: 3.43 posi
Re: Rusted deck lid
mine looks just like that but closer to the edge . in some spots i can almost put a thumb through it my hood is like that too , friggen rust. lol
Old Sep 13, 2007 | 06:09 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Rusted deck lid
Yea, you guys bring up a good point about the sealant on the spoiler bolts. I ill bet $20 that when I pop those caps of that there wont be any seals or anythign aroudn the bolts. I say this bc the last guy that painted it did a real half *** job and painted over rust spots and crap so now im in the process of undoing this damage.
Well Ill pop the caps off and if its rusted really abd on the inside Im most likely going to get a replacement deck lid with a z 28 high rise on it. Good excuse to change over lol.
Thanks Guys!
Old Sep 13, 2007 | 07:25 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Rusted deck lid
HA well heres the result http://images1.filecloud.com/589693/DSC02412.JPG . Popped out the caps with a screwdriver and when i took the one out in the picture the rust just collapsed through it was that bad. Took the spoiler off and there was about 1/10 of the rupper washer seal left on the bolt ...time for a new deck lid.
Old Sep 16, 2007 | 11:41 PM
Kandied91z's Avatar
Re: Rusted deck lid
if it's rs usually $50 in good shape unrusted. z28 goes for much much more.
Old Sep 16, 2007 | 11:51 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Re: Rusted deck lid
it depends, I just picked up a deck lid the glass still attached and the spoiler for $20... people that are parting out cars will sell them for dirt cheap.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
