Steering column rebuild time?
Old Sep 27, 2007 | 07:02 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
The steering column shaft in my IROC has excessive play where it couples to the steering coupler assembly. I can grab onto the end of the steering column shaft and see the excessive play and whenever I turn the wheel sharply it clunks.. I replaced the steering coupler shaft because it was shot but think that the bearings in the column itself are shot as well.
If you've encountered this problem, and or if you've rebuilt the steering column, I'd appreciate your feedback.
Old Sep 27, 2007 | 07:11 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Steering column rebuild time?
Vader posted the most definitive instructions I've seen yet on tearing into the steering column in this thread:
https://www.thirdgen.org/forums/tech...int-loose.html
Old Sep 27, 2007 | 07:46 AM
Wadebryant's Avatar
Thanks NAF.
Are the bearings inside the column that support the shaft assembly subject to or prone to failure also? Grasping onto the end of the shaft assembly in the engine compartment, the shaft has what seems to be excessive lateral movement. Is that normal? Or should I be focusing on repair of the tilt side of the column?
Thanks again.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
evilstuie
Feb 28, 2016 03:33 PM
Bull86
Aug 10, 2015 05:43 PM
