primer on an engine
Old Sep 29, 2007 | 09:57 AM
jlc84cam350's Avatar
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
primer on an engine
hey, i want to paint my 350 before putting it in my camaro, what would be the best way to do this, what do i take off, and should i use primer. thanks
Old Sep 29, 2007 | 02:52 PM
JimmyDavidson's Avatar
Car: 1984 Camaro z28/SC
Engine: 355
Axle/Gears: 9bolt 3.89
Re: primer on an engine
We just used Duplicolor Engine Enamel with Ceramic.. They make Engine Primer too. You can get it at WalMart, or any auto parts store in many different colors.
It has held up so far, so id say it's pretty good paint, you just have to prep it good. Take off or mask whatever you dont want to paint. Most people paint the block, the heads, oil pan and intake, sometimes the valve covers. We have aluminum heads and intake, and chrome valve covers and oil pan, so we only painted the block.
Old Oct 4, 2007 | 11:04 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
If you want to paint the engine body color, I have had good luck primering with PPG DP90 Epoxy Primer, then using a single stage paint that matches your paint code. I personally use Imron for engines because it handles heat expansion well. Imron is toxic as hell, so use precautions.
Old Oct 4, 2007 | 11:16 PM
DZ302's Avatar
ACRYLIC ENAMEL HOLDS UP REALLY WELL. I HAVE PAINTED SEVERAL ENGINES AND THEY ARE STILL HOLDING UP. SINGLE STAGE URATHANE HAS CLEAR MIXED WITH THE PAINT SO IT WILL TEND TO YELLOW IN TIME FROM THE HEAT.
Old Oct 5, 2007 | 04:16 PM
Transmission: th350
ok thanks guys, i don't plan on doing the fanciest thing in the world, but hey, what should is use to clean before spraying?
Old Oct 6, 2007 | 11:12 AM
oldyellow49's Avatar
Usually scrape off any heavy deposits, then follow up with hot soapy water.
Old Oct 6, 2007 | 11:20 AM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
I think it would be a good idea to get it hot tanked.
Old Oct 6, 2007 | 10:13 PM
DZ302's Avatar
3M solvent cleaner or laquer thinner
Old Oct 10, 2007 | 05:42 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
right before you paint it spray it with brakleen or equivelant to get all of the last minute bs off of it. it doesnt leave a residue and it evaporates very fast, thats what i did to mine. then i put 3 coats of grey engine enamil with ceramic primer on it, then 3-4 coats of the color you want , then let dry and put on 2-3 coats of clear coat.. hope this works for you. it did for me
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
