Monte Carlo Compatible?
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Was watchign the power block and on horse power they are working on making a 502 86' Monte... But Im sort of fond of the front clip on that car... Now i have no clue if they are close ro way off. But does anyone know if the front would work.. Not the fenders but the like bumper cover or what ever it is called? Or if that wouldn't... Heres some pictures of the front bumper...
fit how about fenders/hood/and bumper cover?
fit how about fenders/hood/and bumper cover? Senior Member
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: Monte Carlo Compatible?
well....i've seen the camaro nose on an el camino and the el camino and monte front clip are basically the same as far as i know. it might not be a direct bolt on but i'm sure you could make it work if you really wanted to. personally, i dont think it would look too good.
just looking at them it doesnt look like they would fit.. and even if by some chance you could put a monte from clip on a camaro the body lines wouldnt line up and it would look horrible. personally i like the camaro front end alot better
a camaro nose on an el camino? ive always wanted to see that got any pics? ive seen monte noses on an el camino could you be getting them confused?
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
And its not an exact match, i believe that nose is aftermarket. Headlight indentations are shorter. the whole thing is sunk in.
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I believe the company that sells/sold those is Lauren Engineering, I'm not sure there still around. IIRC, they also sold a kit that made use of a Lumina front end.
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
I like the way thos headlights look... any idea if they would swap over into the Camaro?
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
the camaro front end on el camino IS aftermarket a company called Lauren Engineering makes them (http://www.laureneng.com/) my brothers looking into building one. A montes front end will not fit without Major modding
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
