Please help Door pictures
Old Oct 22, 2007 | 09:06 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I am in desperate need of some door pictures from an 82-84 camaro door. What I am having trouble with is mounting the triangle piece for the corner part of the window. My body guy took everything apart and I can't figure out how to put it back together. Also it seems as if newer doors mount the piece different. I have seen pics of newer doors and the have holes where mine does not. Thank you.
Kevin
Old Oct 22, 2007 | 11:00 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Re: Please help Door pictures
Does this help?
Old Oct 22, 2007 | 11:12 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
It does for another part I am putting together. But I need a real picture for what I am looking for. Thank you.
Old Oct 23, 2007 | 01:27 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
I don't have any "real" picutres as I don't have my doors disassembled. But here are some scans from the 82 shop manual. Based on your description, i think you are trying to install the "Filler at Belt", the black trianglar rubber piece at the front of the window. Note that the Glass Front Runner Channel also bolts to the Filler at Belt assembly, after the assembly is installed.
=+++++ from the shop manual+++++===
FILLER AT BELT
Removal and Installation
1. Remove door trim and detach water deflector.
2. Remove front attachments for door weatherstrip and position weatherstrip to provide access to filler bolts.
3. loosen 2 bolts on filler below beltline
4. Remove not on adjusting stud (Fig. 5-31)
5. Remove bolt attaching front run channel to filler.
6. Pull filler up and remove through belt opening.
7. To install, reverse removal procedure.
=++++++ end+++++===
Just to give you some idea how GM described removal & installation.
Attachment 1 is Figure 5-25 "Door Hardware Attachments"
Attachment 2 has Figure 5-31 in the upper left side of the page.
Attachment 3 is Figure 5-33 "Glass Front Run Channel Retainer"
Your best bet may be to download the attachments and view them in Windows Picture and Fax Viewer so you can rotate and zoom as necessary.
Dave
Attached Thumbnails Please help Door pictures-82_door_1.jpg   Please help Door pictures-82_door_2-.jpg   Please help Door pictures-82_door_6.jpg
Old Oct 23, 2007 | 07:33 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Thanks for the pics guys. I think I figured it out from looking at the pictures it looks like they changed the design of the channel and door triangle piece. I appears that I have been trying to install newer window hardware in an older door. Thanks guys.
Also it looks like on the older style the triangle piece and channel are two seperate pieces. Where as the newer one is one piece.
Old Oct 23, 2007 | 11:12 PM
Glad the scans helped you figure out what the problem is. It doesn't help get the door together any faster, but at least you aren't trying to fit peices together that won't go together.
Good luck on getting your door(s) reassembled.
Dave
Old Oct 24, 2007 | 05:11 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Yes thay are different. If you have the older style you can still get them from GM new.
Old Oct 24, 2007 | 07:31 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Really. I will have to make a phone call today.
Vintageracer
Jan 10, 2020 05:33 PM
NiG
Sep 2, 2015 06:54 AM
chubsworth
Aug 26, 2015 02:34 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
