How to remove the t top bar
Old Oct 30, 2007 | 03:41 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
I was wondering if any one had a pics or could explain the best way to remove the t top bar without bending or breaking it or even a step by step guide thanx...charles
Old Oct 31, 2007 | 07:30 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Re: How to remove the t top bar
remove the 4 visible screws that you can see from under each t top, pull the rubber out from it, there will be two more screws under the rubber, take them out, and get a pry bar, but be gentle...it is glued on both ends to take your time....it will pop off in no time.
Old Oct 31, 2007 | 07:37 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I used a sawzall and cut the whole bar off, it is a rust catcher anyway '
For the asker, use the search feature and you will find your answer.
Old Nov 3, 2007 | 08:00 AM
Frank89IROC's Avatar
https://www.thirdgen.org/ttops
Old Nov 3, 2007 | 08:10 AM
Helpfuk link:
https://www.thirdgen.org/ttopleakfix
Old Nov 3, 2007 | 05:55 PM
jcrock17's Avatar
Car: 85 Trans AM
Engine: 305 H
Transmission: 5 Speed
What is a good way to remove the old cement? I read the articles and it did not say. Also some of the lip on the body is missing where it curves into the middle. Should I fix that with new body or just clean and leave it?
Old Nov 3, 2007 | 06:15 PM
To remove the cement, 3M makes a very good "adhesive remover." Most auto part or Home Depot type stores carry it. If you want something a little cheaper that works well, pick up a can of BUG & TAR remover at most auto part stores. As far as any missing metal, if it's like a very small hole, I would clean off all the rust and coat it with some POR-15 or other similar product that converts rust to primer and then fill the holes (if small enough) with epoxy. The 2 part stuff that hardens like steel.
Old Nov 4, 2007 | 11:32 AM
jcrock17's Avatar
Car: 85 Trans AM
Engine: 305 H
Thanks frank.... Appreciate it.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
