Iroc hood mod
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
Iroc hood mod
I went to the junkyard and found a Iroc hood with the louvers missing so I bought it and was thinking of doing something different then running around trying to find these plastic louvers.
I was thinking of maybe putting diamond plate there or sheet metal to make it look like a Z28 hood, what are your thoughts on this?
Also here are some pictures of the hood if you could photoshop diamond plate were the plastic louvers go I would appreciate it.
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: Iroc hood mod
i agree. if you have not bought the hood, save your self the trouble and find another one. the two rear corners are dented along with a dent in the right side. lots of work for a junk yard hood.
Car: 1998 Mustang
Engine: 3.8L V6
Re: Iroc hood mod
Well I already fixed the passenger side corner dent sticks up a little bit but I can live with it and there is no other dent besides the tiny ones that almost every hood has.
And I already know someone local that might have some louvers that I can buy, and I can not pass this deal up $31 and these hoods are not easy to find that are cheap and local and not rusted or smashed.
Car: 1998 Mustang
Engine: 3.8L V6
Re: Iroc hood mod
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: Iroc hood mod
Could they really not justify making it an even $30?
Car: 1998 Mustang
Engine: 3.8L V6
Car: 1998 Mustang
Engine: 3.8L V6
I decided I am going to try and get some louvers for it instead of ricing it out
Here is some pics.
. Here is some pics.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Iroc hood mod
It did come to $30 even but sales tax was a $1.95.
Car: 1998 Mustang
Engine: 3.8L V6
Iroc8t8
May 4, 2026 08:09 PM
mustangman65_79
Aug 11, 2015 03:17 PM
