GFX removal and color change
Old Nov 26, 2007 | 12:59 AM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
I would like to paint my GFX black, but I have a few questions.
How do I remove them? How do I patch small cracks on the GFX? What could I use to cover the spots where it says RS? I just want to smooth over it.
Old Nov 26, 2007 | 03:08 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: GFX removal and color change
GFX are screwed in to the body on the bottom and held on with a double sided molding tape on top. (on my 88 at least). i would say you could patch a small crack with a plastic bumper repair kit from any auto store. as for smoothing, i dont know. fiberglass, plastic body filler, maybe even the same plastic apoxy from the bumper repair kit. ...good luck.
Old Nov 26, 2007 | 03:12 PM
racerx520's Avatar
irockid, you are correct, it is just screws and tape really and to repair the small holes i would personally suggest fiberglass, just make some fiberglass salad and try patching them up i would say....and the RS symbol, i would say the same idea, fiberglass salad all in there, but thats just my opinion
Old Nov 26, 2007 | 06:29 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
You're rocker GFX has 3 nuts you'll need to remove. 2 by the RS emblem (remove the inner fender panel to access) and 1 right in front of the rear wheel. (removal of seat & interior panel to access)
The piece on the door has about 6 nuts to remove. ( removal of door panel necessary)
The piece directly behind the rear wheel also has 2 nuts to remove. (accessed by removing the interior panels in back)
Those that are held on by tape were most likely removed previously. I had no adhesive tape on my original 92 when I removed them.
Old Nov 26, 2007 | 08:32 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Right, there should NOT be any double-sided tape holding the GFX on. Just screws, nuts, bolts and a few clips on the front spoiler.
Old Nov 27, 2007 | 01:27 AM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
this is very helpful, thank you
Old Nov 27, 2007 | 10:43 AM
Camaro0605's Avatar
Car: 1991 RS
I thought the door pieces are also riveted on the bottom? I tried getting a door piece from a yard and i thought i had to drill the rivets out to get it off.
Old Nov 27, 2007 | 01:13 PM
CYARS92's Avatar
Only the actual fiberglass piece is riveted to the metal support bracket. Removing the nuts behind the door panel will remove the whole assembly.
Old Nov 27, 2007 | 01:59 PM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
some one along the line must have changed the way they are mounted on my car when they replaced the front fenders.
Old Nov 28, 2007 | 09:38 AM
emory 4-4-2's Avatar
when i was removing my side pieces, they would not come off the clips. they were wedged on very tightly, and ripped when i pulled them off. i would rather fix than replace them, but i am still curious if i did something wrong or if maybe i happened upon another problem with my car. it's a 92 rs
Old Nov 28, 2007 | 08:13 PM
Engine: that I like
The only clips on a '92 are on the sides of the front spoiler. Everything else bolts on from the back side and has 7mm screws along the underside.
Old Nov 28, 2007 | 08:24 PM
racerx520's Avatar
worrrrrdddddddd
^^^^sorry, i'm just really bored^^^^
Old Nov 29, 2007 | 01:10 AM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
Frozer!!!
Jan 19, 2024 04:55 PM
LT1Formula
Aug 20, 2015 09:36 PM
perZ
Aug 15, 2015 01:17 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
