Cheap A$$ window tint?
Old Jan 1, 2008 | 12:59 PM
Firebird_dave7's Avatar
Car: 1987 Firebird
Engine: Present=350/4brl, Future=455 H.O.
Transmission: Present=700R4, Future=Richmond 6Spd
Axle/Gears: Now Stock, Later 3.73
How can i get it off, quickly. And how can i clean off the adhesive?
Old Jan 1, 2008 | 02:40 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Re: Cheap A$$ window tint?
You need to use a scraper(like the kind they use to remove inspection stickers)It's pretty much a razorblade with a handle on it. Also put some soap and water on it while scraping it.
Old Jan 1, 2008 | 02:44 PM
firstfirebird's Avatar
Blowdryer helps too to warm it up a bit. Any glue lft can be cleaned with acetone (don't use oil based cleaners if you are having them re-tinted).
Old Jan 1, 2008 | 05:47 PM
Car: 1987 Firebird
ok thanks i will try that tomorrow guys.
Old Jan 1, 2008 | 06:22 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
ammonia also works well.
Old Jan 1, 2008 | 06:25 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
my favorite for nasty window tinting is laquer thinner but, to each his own.
Old Jan 1, 2008 | 06:29 PM
yes thats very true.
Can't go wrong with good'ol LT!
thanks for that reminder flaming ford
Old Jan 1, 2008 | 06:51 PM
You will still need to clean with something that evaprates completely before re-tinting (ie acetone).
Mineral Spirits is also good, but that and Laquer Thinner will leave an oil residue.
Old Jan 1, 2008 | 07:37 PM
I don't think mineral spirits would work well.
to the best of my knowledge lacquer thinner is very fast evaporating and is aggressive enough to loosen old nasty tint.
I know that lacquer retarder would probably work the same as mineral spirits and leave an oily residue behind,but not lacquer thinner.It evaporates as fast as acetone does.
anyways,I would suggest picking up some fast dry lacquer thinner or acetone or even some MEK and wipe the tint down with a rag saturated well,the tint should then peel off easy.Then go back with a clean rag also saturated well and wipe it all again and should be clean as can be.
Old Jan 5, 2008 | 09:19 AM
justatransamguy's Avatar
actually, being an ex tinter i always used some black trash bags, wet the window down with cheap ammonia and just stick the trash bags on from the inside and let sit in the sun for an hour or two and it should peel off very easily, if you do have some stubborn spots scrape with a razor blade, but once you start with a razor blade only use the side you started with otherwise it will scratch the glass. then use some rubbing alcohol and a white scotchbrite pad to clean any excess glue left behind.
Old Jan 6, 2008 | 08:13 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
The above method is what I hear a lot of people doing with a lot of success. also if there's any left over residue try using adhesive remover. It's meant just for that.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Damon
Sep 26, 2015 04:29 PM
